serial number look up
Showing 1 to 9 of 9 results
rollingiron
Send a private message to rollingiron
Hi I am trying to look up a serial number and year etc. on a cat excavator and cant find anywhere on the web to do so. I know this is off topic of antique cats but i was just hoping someone could help me out. thank you
Thu, Jan 7, 2010 8:56 AM
bruce oz
Thank you received: 23
hello rollingiron ,if you post up the s/n we can give yr built ,bruce oz
Thu, Jan 7, 2010 9:00 AM
rollingiron
Reply to bruce oz:
5xk15827 thanks
Thu, Jan 7, 2010 9:05 AM
bruce oz
Reply to rollingiron:
5xk15827 thanks
hello rollingiron ,do you know the model number ,i couldnt find any with that serial number ,
the 315,315b,315bl series excavator has the engine number 5xk ????
bruce oz
Thu, Jan 7, 2010 10:04 AM
rollingiron
Reply to bruce oz:
bruce oz
[quote="bruce oz"]hello rollingiron ,do you know the model number ,i couldnt find any with that serial number ,
bruce oz[/quote]
Hi, it is a 315bl, thats probably why i couldnt find it either. Can you tell the year from the engine number? Thank you
Thu, Jan 7, 2010 10:23 AM
bruce oz
bruce oz[/quote]
hello rollingiron ,i have giving you wrong info about 315bl ,it should have been 315cl.
model with 5xk are 315 (fr ,jp,fr)315b(jp)315c(jp)315cl(jp)
also 317(fr)317bl(fr)317bln(fr)
-318bl(jp)318b(jp)318bl(jp,fr)318bln(jp,fr,)
engine should be a 3046 .
i cannot give yr from the engine number ,will need excavator serial number for the yr built ,bruce oz
Thu, Jan 7, 2010 10:50 AM
Thank you received: 52
Reply to bruce oz:
Hi Bruce oz,
I hope your not relying on that Toughquip Buyer Guide for your serial number info. It appears to be really messed up on the 315BL models. Best I could find is it uses the 3046T engine but do need the series and serial number to pin it down.
315B model 1SWxxxx 3046 5XKxxxx
315B 3AW 3046 5XK
315B 5SW 3054 5HK
315B 5SW 3054 7BJ
315B 7RZ 3046 5XK
Thu, Jan 7, 2010 10:33 PM
bruce oz
Hi Bruce oz,
315B 3AW 3046 5XK
315B 5SW 3054 5HK
315B 5SW 3054 7BJ
315B 7RZ 3046 5XK
hello om ,yes using that book ,lol,have been thinking about getting this one below ,wounder if info is any better,bruce oz
https://www.buypenton.com/ProductDisplay.aspx?ref=EQW&SubjectCode=EQWSN
Fri, Jan 8, 2010 3:03 AM
Reply to bruce oz:
Don't know anything about that book......kind of pricey.......nor do I know of another better source. Kind of haft to use an assortment of sources to get info.
Machinerytrader, Ritchiewiki, lists of manuals, etc.
Fri, Jan 8, 2010 3:52 AM
dpaustin
Send a private message to dpaustin
[quote="Old Magnet"]Don't know anything about that book......kind of pricey.......nor do I know of another better source. Kind of haft to use an assortment of sources to get info.
Machinerytrader, Ritchiewiki, lists of manuals, etc.[/quote]
I hope that we can help you with reliable serial number information. I work with Top Bid (www.topbid.com), a division of Randall-Reilly Publishing, and we publish a very comprehensive guide that includes used Caterpillar serial numbers. Auctioneers, finance companies, new and used equipment dealers, and appraisers use the guide. To access full data, you'll need to invest in our book or on-line subscription, and the Caterpillar 3-digit prefix information is on-line for free. The reason Top Bid can produce this information so reliably is that we check our data against lien registrations and get much of the data directly from the OEM. I hope you'll give us a chance.
Tue, Oct 9, 2012 8:56 PM
