Serial number location on Cat 30
Showing 1 to 9 of 9 results
AndyD2NZ
Send a private message to AndyD2NZ
Can anyone tell me where the serial numbers are stamped on Cat 30 , we don't have the ID plate on the fender,thanks
Sat, Jan 10, 2009 3:24 AM
Paul L.
Send a private message to Paul L.
There are three spots on my 30. On the left side of the engine block below the carb,rear of the transmission shifter cover there is a machined flat spot with serial numbers stamped in it, the third spot is above where the pto would attach at the rear of the machine. Hope thats of some help to you.
Sat, Jan 10, 2009 9:52 AM
Kevin Kalsem
Send a private message to Kevin Kalsem
Reply to Paul L.:
I've also seen them stamped on the block above the main clutch behind the last cylinder jug 😊
Sat, Jan 10, 2009 10:40 AM
AndyD2NZ
Reply to Kevin Kalsem:
thanks guys , I found a number under the waterpump on the block S 1446 it is a cast number not stamped ,and 975 is stamped on the back of the rear housing just in front of the seat bracket (orchard model ) Can some one now tell me what year it was built ?
Sat, Jan 10, 2009 5:08 PM
Paul L.
Reply to AndyD2NZ:
If it has PS in front of the number then it should be the serial no., my book said it would be 1927.
Sun, Jan 11, 2009 9:49 AM
Willie
Reply to Paul L.:
You better look again and look for a P in front of the S or another digit in the number. S1446 would be a 1922 Best30 and would make ie a 2 speed and worth about $20,000 more then your Cat30 LOL
Sun, Jan 11, 2009 10:34 AM
Caterpillarman
Send a private message to Caterpillarman
Reply to Willie:
Hello, s-1446 is the part number for the engine block, not a serial number.
Sun, Jan 11, 2009 3:04 PM
AndyD2NZ
Reply to Caterpillarman:
thanks again all , caterpillarman : I thought that maybe it could be the part no for the block number also, not the serial no,thanks for pointing that out .--- Willie, Ive looked hard and there is no S or PS in front of the 975 stamped on the rear housing and it is a 3 speed with 2 sliding gear levers, so its not a Best, pity. My cat 10 also has the numbers only, no letters in front, so perhaps it's the same , I'll have to keep looking, you keep sending in ideas ,Andy
Sun, Jan 11, 2009 4:44 PM
Willie
Reply to AndyD2NZ:
That no. stamped on back of block is supose to be date it came off the line but I have never figured it out. but the ser. no. will be stamped or on a tag not embossed in casting and unlike later machines the didnt stamp under the tags,look close on top of PTO housing for stamped no. or little tag behind the carb.
Mon, Jan 12, 2009 12:36 AM
AndyD2NZ
Reply to Willie:
Willie :Had another good look for more numbers but no luck ,there is definitly no letters with the numbers on the back of the trany, only 3/4 inch high 975 stamped ,so I'll just have to settle for 1927 . It has had the steering levers out the side but they have been cut off and levers fitted like most tractors have at the back , I'll refit the original type when I find some, cheers Andy
Wed, Jan 14, 2009 3:24 PM
