self-cast carburetortop for the TEN
Showing 1 to 10 of 32 results
MARCOTEN
because the original top from the carb was broken, and a new or 2nd hand-one was not available or very expensive, i cast myself one from aluminium, and machined it down.
on the last picture you can see it mounted and the engine runs fine with it!
[attachment=15024]DSC01894.jpg[/attachment][attachment=15025]DSC01895.jpg[/attachment][attachment=15026]DSC01900.jpg[/attachment][attachment=15027]DSC01918.jpg[/attachment][attachment=15028]DSC01934.jpg[/attachment][attachment=15029]DSC01935.jpg[/attachment]
Wed, Oct 10, 2012 2:39 AM
Mike Meyer
Thank you received: 6
Well done Marcoten, I've often thought a Chinese backyard foundry could make those pesky and hard to find Ensign carburetors for about $3.69 if they had a good sample to start with, and we ordered 50,000 of them, probably only cost $9.99 if we ordered 100 of them!:lol
regards
Mike
Wed, Oct 10, 2012 3:29 AM
chriscokid
Reply to Mike Meyer:
regards
Mike
Looks Good,
I made one out of a block of aluminum.
Wed, Oct 10, 2012 4:06 AM
Snuffy
Send a private message to Snuffy
Reply to chriscokid:
Looks Good,
Both should be proud of your workmanship. Very nice job on both. Have a good day!
Snuffy
[SIZE=2]1937 22, 1939 D7 9G, 1950 D4 7U, 1953 D4 7U,1953 D2 5U, 1962 D7E[/SIZE]
Wed, Oct 10, 2012 6:43 AM
gauntjoh
Librarian
Thank you received: 5
[quote="MARCOTEN"]because the original top from the carb was broken, and a new or 2nd hand-one was not available or very expensive, i cast myself one from aluminium, and machined it down.
[/quote]
Hi Marcoten,
That's a high quality piece of work there.
I'm curious as to how you made the pattern and what material you used for the mould.
Wed, Oct 10, 2012 12:54 PM
MARCOTEN
Reply to gauntjoh:
[/quote]
Hi Marcoten,
all thanks for the replys,
@gauntjoh: for the pattern i used the old carbtop, i glued it back togetter and put some extra filler on it , specialy on corners to avoid the original squere corners, i made them a bit more round for more strengt and avoiding breakege later, also on the place where the fuel enters i made it a bit thicker for this reason.
i made the entrance of fuel not like original as that was a reson that many tops broke because it used to leak and then by trying to tighten it up to avoid the leaking the tops broke
i cast the extra hub on it for making it possible to put it in a lathe and machine it.
As a mold i used fireproof cement as i didn't have real molding sand.
First i tried several other materials like sand, oily sand, sand with cement, and several others, but that didnt had the good results for me.
the white stuff on the mold is a bit quick plaster as there broke a little piece of when i removed the pattern, and i repaired it.
the first casing in that mold didn't succeed, as there was still too much water in the hardened cement (even i left the mold on the bbq for 1 hour) there became steam/gas bubbles in the casting, so i did it again and it was ok now.
for heating up the aluminium i used my propane oxygen torch, but with a bit more propane then a flame for cutting.
it took me a lot of days to make it, but it was very nice to do and with a nice result!
[attachment=15035]DSC01896.jpg[/attachment]
[attachment=15036]DSC01893.jpg[/attachment]
Wed, Oct 10, 2012 5:24 PM
Thank you received: 77
Looks Good,
[quote="chriscokid"]Looks Good,
I made one out of a block of aluminum.[/quote]
Erik, how did you affix the bronze thread into the aluminum block?
Neil.
Thu, Oct 11, 2012 6:40 AM
Steve A
Neil.
Nice Job
I like creative solutions to problems.
Sometimes i wonder why Others and myself put time and money into what seems like a less than ideal carb.
Thu, Oct 11, 2012 7:26 AM
chriscokid
Neil.
[quote="Neil"]Erik, how did you affix the bronze thread into the aluminum block?
Neil.[/quote]
Press Fit.
It turned out nice, but the brass is to repair an opps!
Thu, Oct 11, 2012 7:38 AM
gauntjoh
Librarian
Reply to MARCOTEN:
[quote="MARCOTEN"]all thanks for the replys,
[/quote]
Bedankt Marcoten,
Casting with aluminium is something I've often wanted to try, I've just never had a good enough reason to have a go. I think your experience will spur me on to try it out sometime soon.
Thu, Oct 11, 2012 1:07 PM
Reply to gauntjoh:
[/quote]
Bedankt Marcoten,
Both of these cases are "Thinking outside of the Box".
I had always thought that seeing one machined out of a block was genius, now I am wowed by the pure craftsmanship of actually casting one!
Nice job to the both of you!
Jeff
BTW:
This is a highly Marketable item as there are alot of guys in the world of tractors who have 3 or 4 of these with damaged tops sitting on a shelf in their shops.
Thu, Oct 11, 2012 6:07 PM
