Seeing if a D6 engine is stuck
mikewood869
Send a private message to mikewood869
Progress on our d6 9u has been slow, were going to be looking at a parts D6 9u with a pony engine tomorrow. Is there any other way to see if the main engine is stuck? I was looking at ours and there doesn't seem to be a good way to get a socket on the crank.
Wed, Jan 10, 2024 10:24 AM
Thank you received: 140
Hi, mikewood869.
Hold tension on the fan belts and try to turn the engine with the fan or take the cover off the main clutch housing and try to turn the flywheel. Make sure the decompression lever is at start before trying.
Wed, Jan 10, 2024 11:30 AM
dmgrow
Send a private message to dmgrow
Hi, mikewood869.
1 decompression lever off
2 throttle off
3 put in high gear
4 Lightly bump it with another tractor
Ya have to be careful as you can do a lot of damage if it is stuck and you force things.
Be sure to check the fuel rack to be sure it is not stuck in an open throttle position.
A runaway engine gets pretty exciting very quickly.
Good luck
Thu, Jan 11, 2024 7:09 AM
mikewood869
Reply to dmgrow:
2 throttle off
3 put in high gear
Good luck
Thank you for your guy's help, we ended up not getting the dozer, but are still looking.
Thu, Jan 11, 2024 7:57 AM
