sediment bowl
sediment bowl
Showing 1 to 10 of 11 results
abram
Send a private message to abram
well i managed to drop my 3j d2 pony's sediment bowl today and shattered it into pieces 😠 anyways...where can you get replacments??
3J5 D2
Sat, Oct 25, 2008 6:48 AM
naylorbros
Thank you received: 30
Caterpillar makes a steel replacement for the glass bowl. Give your dealer the part number for the glass bowl and they will give you the steel one. If you want a glass one a trip to the junk yard might be needed.
Ken
Sat, Oct 25, 2008 8:38 AM
abram
Reply to naylorbros:
Ken
cool thanks, i'll give them a call.
3J5 D2
Sat, Oct 25, 2008 9:11 AM
Cat-astrophe
Send a private message to Cat-astrophe
Reply to abram:
Hello, Dana At Florin Tractor in Sacramento stocks the glass ones. I got some from him last year, He's good to deal with, and you are a lot closer than New Zealand!! Regards
Sat, Oct 25, 2008 6:07 PM
your37m
Send a private message to your37m
Reply to Cat-astrophe:
if its the small bowl you can use a 3/4 socket and plastic bottle cap till you get a glass one
Sat, Oct 25, 2008 6:57 PM
Jim Sixty
Send a private message to Jim Sixty
Reply to your37m:
On my D69U I've been using pill bottles that my medicine comes in every month, just cut to length. They will last about a year before the gas gets to them, but it seemed like I could break the glass ones faster that that. Plus these are free.
Jim
Sat, Oct 25, 2008 7:40 PM
chugwater crawlers
Reply to Jim Sixty:
Jim
Try restoration supply @ www.restorationstuff.com. They are in your state.
Or try Sacrememto Vintage Ford. The glass bowl for the old flatheads looks like the same one they put on the 22. Make sure you buy a new gasket. I learned that the hard way.
Sun, Oct 26, 2008 7:01 AM
chugwater crawlers
Reply to chugwater crawlers:
Oops. Can't spell. It's Sacramento Vintage Ford.
Sun, Oct 26, 2008 7:03 AM
abram
great thanks for all the suggestions guys!
3J5 D2
Sun, Oct 26, 2008 8:13 AM
abram
Reply to abram:
well i ended up makin a plastic bowl out of a advil bottle, the screw holder wont fit around the bottle so i rubberbanded it on 😛 it's a temp solution i promisse 😄
3J5 D2
Sun, Oct 26, 2008 11:39 AM
Mike Mahler
Send a private message to Mike Mahler
Reply to abram:
Rubberband? Yes, very temporary....... Better go change it now.
My services shown at www.myspace.com/vintageengine
Mon, Oct 27, 2008 12:21 AM
