Searching for Byron
Searching for Byron
Cat-Iron
Send a private message to Cat-Iron
Needing some quality Cat Cave remain manifolds anyone tell me how to get ahold of the crazy limy,does he look at the forum, other side of the big pond 🤔 best connection for remain manifolds out there if they are available
Fri, Oct 24, 2025 10:51 PM
Cat-Iron
I can't believe that no one has an email address for Byron,after speaking with the acmoc team in Elkader we are trying to revive the club, not seeing it, looking to get cat cave reman big 20 heat boxes, any interest from anyone else who may need one if I'm able to get through to him,top quality work by the crazy Limy any help would be appreciated, thanks to those who know
Fri, Oct 31, 2025 4:35 PM
Thank you received: 214
You might try reaching "sasquatch" on the bulletin board or "deebo". Byron is based in England from what I see on the Bulleting Board postings. Good Luck - cts
Fri, Oct 31, 2025 7:07 PM
naylorbros
Thank you received: 31
[email protected] is what I have been using
Ken
Fri, Oct 31, 2025 7:38 PM
Cat-Iron
Thanks, being the very 1st banned member from this club had lot all the old school contact info,member no.17 of the original first 100 to be able to have one of the commerative buckles, not many out there left,haven't seen any of them on this forum, kinda a shame,Byron is definitely a character but stepped up when the banning came,he got it also,No.2,politics, does the best job of making manifolds u will ever see,have a stack of them to prove it, used a few and spot on,needing a heat box for a big 20 bought on that Iowa auction, extremely straight and clean original tractor, anyone would be proud to own, completely overhauled using cat 25 jugs and pistons, could run it the way it is but the new box would be great, anyone else maybe needing one could maybe post,I know it takes multiple to make a run,thanks for the email address will be good to chat to the crazy limy 🫠🫡
Sat, Nov 1, 2025 10:46 PM
Busso20
Cat-Iron, if you get timing right it sounds like he does batches of parts, so if in luck he will have on the casting plan sooner than later.
Sat, Nov 1, 2025 11:12 PM
naylorbros
Two L/PL heat valves and an 8C heat valve from Catman on my bench
Sun, Nov 2, 2025 4:05 AM
Cat-Iron
Actually sent an email and got a reply from Byron, takes 4 orders to make a run,willing to step up 4 - 2 of them need anyone interested in maybe acquiring 1 or 2 to maybe sign up also, after a brief walk through the shed have 2 good sets on 2 different tractors but really hate to strip them off,one is on a 25 and the other is on another big 20,decent tractors that need a new home,don't want to cannibabize a complete tractor for a manifold piece, anyone else who would be interested in maybe getting a heat box please step up and we'll get them built, the crazy limy is game to get it done,thanks
Mon, Nov 3, 2025 12:03 AM
Deebo
Librarian
Thank you received: 105
Chris Lee in the UK would take one!
Tue, Nov 4, 2025 3:48 PM
