Seals on hydraulic control valve
m rust
Send a private message to m rust
I have a D6 5R. My hyd control valve is leaking on the top cover. There are 4 bolts on the top cover that holds it down and the lever. Were would you get a seal for this? And is there anything i need to know in removing this cover? Don't want to break anything.It is a Laplant Choate Serial Number 7654.
Thu, Apr 25, 2019 8:09 PM
They don't use a conventional lip type seal. Under the bonnet is a spring loaded packing gland (In addition to the valve plug spring). Replace the packing with a graphite type rope packing.
Fri, Apr 26, 2019 6:39 AM
m rust
Were would i get the packing?
Fri, Apr 26, 2019 8:35 AM
Reply to m rust:
Used to be that pump suppliers would have an assortment of packing. String packing is still available at most plumbing supplies. Might look into McMaster-Carr industrial supplier. If it is a square cross section packing you will need to get dimensions.
Fri, Apr 26, 2019 10:06 AM
I don't think it will do much good but the LaPlant-Choate seal assembly part number for the control valve is 19899.
Have no idea where you might source it.
Sat, Apr 27, 2019 12:31 AM
m rust
Found a control valve from a D7 that was the same. Took it apart and it had a round flat cork seal,and a cone washer that went up to it to seal it. Took mine apart and it was missing the cork seal And the spring had lost its tension. Should be fine now have not had a chance to run it yet because of it raining.😊
Sat, Apr 27, 2019 9:25 PM
