Scarifier part question reguarding the (1D3537) Wedge
Russelln
Send a private message to Russelln
I found in our barn about a dozen shanks with the tooth attached for my #12 grader, but no where could I find the Wedge's used to hold them in.
Does anyone have a 1D3537 Wedge that they can get the dimensions off of and post here, I'm thinking we may be able to make these rather then buy them.
I think I found an after market source from a company called Romac that lists them as a 5K1458 but they claim each one needs a 5K1459 Grommet to go with them which looks like nothing more than a cut piece of clear fuel line. I'm assuming that this grommet keeps the wedge from becoming perminate installation.
Cat 12 Grader 8T6375
Cat D8 2U12593
Sat, Jan 25, 2014 10:13 PM
You want the 1D3537 wedges.
Regal lists them for $11.72 ea.
or try Acme Rigging & Supply Co. in Sacremento or Ukiah
Sun, Jan 26, 2014 12:31 AM
Russelln
[quote="Old Magnet"]You want the 1D3537 wedges.
or try Acme Rigging & Supply Co. in Sacremento or Ukiah[/quote]
Thanks Old Magnet, I found two of them in a box with some railroad spikes, Looks like the spikes were used as wedges at one time.
I sent a email off to Regal and gave Acme a call Monday.
I did call Florin in Sac, but they had none in stock at this time.
Cat D8 2U12593
Sun, Jan 26, 2014 10:20 AM
Reply to Russelln:
If you need more sources plug the number in to a Machinery Trader parts search, seems to be plenty of them out there. If all else fails I think I can come up with the dimensions but hardly seems worthwhile fabricating.
Sun, Jan 26, 2014 10:37 AM
