Saved from the scrapper
Showing 1 to 10 of 12 results
Eds-oldiron
Send a private message to Eds-oldiron
The mgr. at the scrap yard called yesterday and says he has an old crawler I should look at. Turned out to be a Twenty, SN L850. Sure glad scrap prices have come down. Yes... it did follow me home today.
It is missing sheet metal, fan blade, mag, carb, intake extension, air filter cup, and the hand crank. The exhaust manifold is rough, undercarraige looks good, and the engine is not stuck. Anyone with spare parts??
Sun, Apr 26, 2009 12:43 AM
raklet
Send a private message to raklet
Nice find. Have fun with the restoration.
Sun, Apr 26, 2009 1:03 AM
Thank you received: 140
Reply to raklet:
Hi, Eds-oldiron.
The tinware may be missing from around the engine but it's ALL there and REMARKABLY straight on the tracks.
If that old plow seat is replacing the original upholstered seat, it would have less back support but probably more spring than the original and would have been cooler to sit on due to the ventilation - - - unless left out in the sun. Then - one hot butt.
Good catch. Thanks for sharing. Happy restoring.
Sun, Apr 26, 2009 5:47 AM
Tom Madden_archive
Hi, Eds-oldiron.
. . . and she is a wide gauge!!
Sun, Apr 26, 2009 6:02 AM
Reply to Tom Madden_archive:
What is the bunch of pieces that are on the rear end?
Some sort of 2 point or crude 3 point lift system?
Sun, Apr 26, 2009 8:11 PM
Eds-oldiron
Reply to drujinin:
The pieces on the rear make up a hyd tool bar that would hold CAT style scarifier shanks. The shaft above that looks to have held a spool of?? maybe?? There is the remains of what appears to have been a chain drive pump off the mag drive shaft.
Mon, Apr 27, 2009 5:40 AM
Reply to Eds-oldiron:
I couldn't make out what it was in the first photo. Too shadowy.
I see it more clearly now.
Mon, Apr 27, 2009 6:44 PM
Eds-oldiron
Reply to drujinin:
While taking a better look at this attachment, I noticed 3 more brass tags riveted to the inner fenders. One is a lube chart and can't make out the others. Will have to get some better light.
Took another look at the tags. Can someone tell me if this is a factory location for the tags. The two on the right are a patent # tag, and I can only make out "track tractor" on the other. Even without all the added iron on the rear, it would still be difficult to read the lube chart on the left side, without getting on your hand and knees. Thanks Ed
Wed, Apr 29, 2009 12:56 AM
OneWelder
Send a private message to OneWelder
I do not know much about them - but some of those old cast iron seats are worth a lot more than you would think- The Amish look for certain ones as well as some very serious collectors.
Wed, Apr 29, 2009 5:54 AM
Eds-oldiron
Reply to OneWelder:
This is a simple stamped tin seat. Me thinks it not worth much.
Wed, Apr 29, 2009 9:57 AM
catcrazy
Send a private message to catcrazy
I can't beleive that anyone would simply scrap such an awesome antique, good luck & keep up the good work. Wish that I could find some "scrap" like this myself.
Thu, Apr 30, 2009 6:42 AM
