Saved from the fire wrench !!!!
Showing 1 to 6 of 6 results
vernier
Send a private message to vernier
Today I went and looked @ a couple of graders that were heading down that no return path. They are both way too good to let go that route. One is a 12 serial# 70D3311, the other is a 112 serial# 3U413 ? (couldn't see this one real clear) Could someone tell me the approx. year of these two machines?
Vernier
Fri, Feb 9, 2007 8:14 AM
The 70D is a 1959 model.
The 3U is 1953
Better grab em😄 😄
Fri, Feb 9, 2007 8:37 AM
vernier
The 3U is 1953
Better grab em😄 😄
Thanks Old Magnet, will an engine out of an 8T work in that 70D machine ?
Fri, Feb 9, 2007 9:30 AM
Reply to vernier:
Amounts to putting a D4600 in place of a D318. Certainly has been done on tractors but may be a little different on graders and their transmissions. I've never done it but would say yes unless others know otherwise😊
Fri, Feb 9, 2007 9:49 AM
muzz
Send a private message to muzz
I thought the a 8T #12 grader and a 70D #12 grader both had D318 engines.
Muzz
Fri, Feb 9, 2007 8:26 PM
SJ
Send a private message to SJ
OM the 8T grader should have the D318 engine in it as they came out in 1947.
Fri, Feb 9, 2007 9:10 PM
Reply to SJ:
Yup, you guys are right, D318 in both. Sorry about that😮 😮
Fri, Feb 9, 2007 10:40 PM
