Safe/easy way to elevate tracked cat for maintainence?
Showing 1 to 10 of 26 results
case on a cat
Send a private message to case on a cat
I'd really like to get under my D2 to change oils and get to all the grease fittings. There is not a lot of room.
I've thought about digging a slot in the ground. Just few inches would help a lot. Ive also thought about bolting 2 pairs of RR ties together with heavy all-thread and plates for washers. I'd lay the bolted ties down so they are side by side under each track.
I'd be worried about the hole caving in and just being a muddy mess. I'm leaning towards the RR ties, but I'm not 100% convinced that's safe either.
Any better ideas?
Wed, Dec 28, 2016 9:38 PM
kracked1
A RR tie under each track works great. If you can find a couple nicer, fairly square ones is even better.
Wed, Dec 28, 2016 10:38 PM
cheshire cat
Send a private message to cheshire cat
Reply to kracked1:
Any decent pieces of timber will be fine , just don't use concrete brick etc ...
Wed, Dec 28, 2016 10:54 PM
Reply to cheshire cat:
One each RR tie per side is what I use. Problem is in Ca. they have been banned due to creosote so they can be hard to find.
Wed, Dec 28, 2016 11:11 PM
I dug a slot in the ground about 12 inches deep---made the walls out of 2 rr ties each on top of each other--inside ID equaled the id of my 4U tracks--long enough to reach belly pan from rear---slight slope to slot draining out the open end so need ground that is on slight slope to build it
can't find the pic right now
Thu, Dec 29, 2016 12:59 AM
Thank you received: 77
Reply to dpendzic:
You can also just pick up a couple of 4x4s or 6x6s from Home Depot. They don't have to be railroad ties. If you pick up a few, you can build a custom height and width. If you have a slope, you can dig them into the slope so you can drive on level. If you get really fancy, you can use some 6x6s as piles and basically make an open air pit you can stand under
Thu, Dec 29, 2016 1:48 AM
The benefit of RR ties is they are treated to reduce rot.
If your going to use anything else make sure it is pressure treated lumber.
Thu, Dec 29, 2016 2:44 AM
case on a cat
I already have a few RR ties handy. They all pretty straight and real solid. I got a good line on used ties, for now anyway.
Thu, Dec 29, 2016 2:52 AM
mrsmackpaul
that is amazing OM almost unbelievable to me but I have heard some amazing things about California
And yet we can by it over the counter out here still from most hardware shops
Thu, Dec 29, 2016 3:12 AM
Reply to mrsmackpaul:
Creosoted timber was banned 2 years ago in New York State---so was CCA treated timber so they now use CZA treatment---but none nowhere as good as the creosote
Thu, Dec 29, 2016 4:35 AM
Walt D7-3T
Send a private message to Walt D7-3T
Reply to dpendzic:
All,
I cannot contain myself any longer. All the mentioning of things that have been banned here and there just irritates me!
Do any out there realize that air, water and even food is hazardous to us humans?
It is proven that if you breath enough air or drink enough water or eat enough food, you WILL DIE?
So I think we humans NEED to stop being so silly about things we have banned. SHEESH!:target:
Thu, Dec 29, 2016 9:18 AM
