Rustoleum old cat yellow paint is way off for my Cat 22
Showing 1 to 10 of 41 results
22Catter
Send a private message to 22Catter
I purchased a Gallon of Rustoleum Old Caterpillar Yellow only to find that the color is so far off from the original yellow on the 22 I cannot use it. The yellow on my 22 is original .It even has "Caterpillar manufactured in Peoria,Ill on the back so I know it is the original paint . The original paint is a much lighter yellow than the Rustoleum stuff. Does anyone know of the true yellow for a 1934 Cat 22 and if so where I could get it ? Any help is greatly appreciated.
Mon, Dec 10, 2012 3:12 AM
gwhdiesel75
Did you take into consideration that paint fades in the sun over the years?
Mon, Dec 10, 2012 3:24 AM
Reply to gwhdiesel75:
I agree with GW on the fading issue.
Mon, Dec 10, 2012 3:42 AM
22Catter
I have considered the fading as a possibility and so machine polished an area and indeed some change but still nowhere close .
Mon, Dec 10, 2012 4:23 AM
zootownjeepguy
Reply to 22Catter:
I'm with the crowd here. Polishing paint that has seen over 7 decades of UV rays probably won't bring back the original color. I have a NOS Caterpillar dash light for my D2 and the color is very close to the Rustoleum Old Cat Yellow, that light has not been in the sun for over 70 years.😛op2:
Rich Salvaggio
D2 5U9917
Mon, Dec 10, 2012 5:57 AM
22Catter
Reply to 22Catter:
I have a toolbox off a friends Cat 22 so I machine polished it and the Rustoleum Old Cat yellow paint was a good match to that. So I will get custom mix for my existing Cat Yellow original paint as apparently it is somewhat unique . This was the color it was when my Grand Pa bought it new .
Mon, Dec 10, 2012 6:06 AM
Steve A
Reply to 22Catter:
I painted my small 15 with paint that was mixed per the color code listed on this site. I was unsure but blamed it on the flouresent lights in my shop, When I got to the Show in Bowling green I was 10 shades lighter than any other Cat, what a bummer, Will be repainting this spring when I get the side curtans
Mon, Dec 10, 2012 8:25 AM
terrywelch_archive
Reply to Steve A:
Paint does fade and after all those years should be faded. You have to remember that Cat like a lot of other tractor manufactures was not worried on the color match as they were on the performance of their machines. They put the standards out and if they run short from a supplier . They may get it from another supplier and it may not match that well. As suggested find some paint under a gauge, fuel tank or behind something painted. See how it matches there.
Terry
Mon, Dec 10, 2012 8:46 AM
hiwide15
Send a private message to hiwide15
Reply to terrywelch_archive:
Terry
I just got a gallon on fri and its right on color.
Mon, Dec 10, 2012 9:36 AM
janmeermans
Reply to hiwide15:
I'm using Cat Part No. 4C4185 which I thought was the original "Hiway Safety Yellow" which is not the current Cat Yellow. My dealer has it in stock. I was lucky that 2 gallons came with my tractor when I bought it so cost was not a concern.
Jan -Cat 15 PV 7207
Mon, Dec 10, 2012 11:41 AM
hicrop10
Reply to janmeermans:
Jan -Cat 15 PV 7207
I used the Rustoleum to paint my Cat15 Motorpatrol and the color was great.It was easy to use and spray.If the two gallons that you said came with the tractor is what you are basing this all on,could it be that that is old paint, or didn,t Cat remove some of the lead in their paint that was used in CA.before changeing colors.
Mon, Dec 10, 2012 8:01 PM
