Running on three cylinders
Showing 1 to 10 of 29 results
Tiahoa
Send a private message to Tiahoa
Well, I seem to have an issue 1968D333 turbo marine diesel. Everything has been running perfectly until this morning. I started it up and it acted like it needed a better prime like air. Anyway, it fired up, but it was only running on three cylinders, yesterday It ran perfect at the dock, I have not taken her out yet, so I’m glad this issue happened here at the dock, but I don’t know what caused it. I had recently changed all The filters the fuel is clean, so I’m not sure what the problem is. I cracked the front three injector lines and those are the three running the back three are squirting but they’re not firing…. I thought let me change a nozzle. I moved number two to number five no difference nothing followed. It’s like the back  three from the pump are not making a fire. I smell raw fuel it’s a little bit smoky I don’t know what to do. I’ve tried checking for leaks I’ve tried priming, filters are clean. i’m kind of at a loss with this one. Any thoughts or ideas would be appreciated
Fri, Mar 7, 2025 12:59 AM
Thank you received: 61
One by one disconnect the feed line to the injector and with the engine running check to see if you have air/bubbles at the injector connection. Seems you may have compression leaking back into the injection pump/s.
Fri, Mar 7, 2025 4:18 AM
Tiahoa
Well Gee that sounds like it could be expensive I wonder what would cause that don’t tell me my pump went bad..
well I will try that out and see what I find. Thank you for the help and the reply hopefully we can figure this out strange that all three cylinders would just be gone together
Fri, Mar 7, 2025 6:38 AM
Tiahoa
Reply to Tiahoa:
[quote="Tiahoa post=261983 userid=17933"]Well Gee that sounds like it could be expensive I wonder what would cause that don’t tell me my pump went bad..
OK I tried that didn’t really see any air bubbles but it may be that there is when I cracked number five it seemed like there was a shot of air and then it was just fuel,, I am getting an oily residue out my exhaust it is Diesel he just leaving a sheen on the water and it’s never done that. Also at a dead idle, it seems like it’s running on four cylinders the first four I swap nozzles, 12 and three with 45 and six, and no change beginning to think my pumps shot somehow.
 [/quote]
Fri, Mar 7, 2025 7:21 AM
Reply to Tiahoa:
 [/quote]
All it takes is for one bad injector or its seating to allow compression to back feed into the injection pump common feed passage. The #5 you mentioned, was the air coming from that injector? not the feed line? Not having three cylinders firing causes the remaining good cylinders to load up and be over fueled. If you are getting fuel from the injection pumps when checking flow there is nothing wrong with the pump/s. Problem is as soon as you reconnect the feed lines to the injector you start the compression leak displacement of fuel all over again.
If you have trouble detecting back flow at the injector connection, squirt a little lube oil in the opening and see if it gets bubbles or blows out.
Fri, Mar 7, 2025 1:13 PM
Thank you received: 54
so to clarify OM you recommend, remove the injector line and crank the engine if bubble form on the injector fitting it's not seating properly and allowing compression pressure back into the injection pump stopping it from working correctly.
Sat, Mar 8, 2025 8:01 AM
Reply to trainzkid88:
Well, yes, that's sort of the short version.
Another thing to check is to see if there is a suction/air leak ahead of the transfer pump.
What is the fuel pressure reading?
Sat, Mar 8, 2025 10:58 PM
Tiahoa
So I found that number six after pulling them out and checking them and looking them over and for whatever stupid reason I decided to blow through one and I could blow through number six not the others but I thought well shoot there’s a problem just like you said, so I ordered six new ones anyway and will report back once I get them put back in and all that business. Thank you old magnet, for your help and direction of where to look. I hope that doesn’t affect the seals in the injector pump for pushing fuel into the oil or anything..  I sure do love the way these girls run good on fuel good power just a sweet old engine.
Mon, Mar 10, 2025 6:31 AM
Reply to Tiahoa:
Seems you are on it!!! Better to find it's an injector problem rather than a seating problem which could lead to changing a pre-combustion chamber.
That's not going to have any adverse affect on the injection pump/s
What's the actual serial number of the engines? Those actually may be D333C engines.
Mon, Mar 10, 2025 7:07 AM
Tiahoa
80b00613/ 614 matched set, definitely D333 marine, not d333c
Wed, Mar 12, 2025 10:30 PM
Reply to Tiahoa:
Actually they are D333B engines.
Wed, Mar 12, 2025 10:55 PM
