Rubber Track Pads
Rubber Track Pads
Showing 1 to 9 of 9 results
3J1Bill
 [attachment=68899]P1040686.JPG[/attachment]The weather finally cooled off enough to get some work done on the CAT 22 . Bill
Sun, Sep 11, 2022 6:20 AM
Thank you received: 288
Nice. Did you buy those from John S? or did you make your own adapters, etc? I by pure luck found a set of surplus ones on FB of all places from a JD guy that did not want them; of course that was a couple years after I already bought a nice set from John. Per his comments, it should take approximately 4.5 hrs to bolt them on. He was pretty darn close!
Those sure make parading around nicer. I have driven my D2 down the road before in 5th gear and received a few stares...I have also used the tractor to disc with and pull scraper with with no issue, other than a little slippery on wet grass (even the big rubber tracked units do that)
Sun, Sep 11, 2022 8:08 AM
Thank you received: 54
they also had steel road shoes as a genuine accessory for machines drawing trailers etc on the road network.
Sun, Sep 11, 2022 1:09 PM
3J1Bill
Reply to trainzkid88:
Yep, I bought them from John. They fit nice and went up the paved driveway without leaving a mark. It did take about 4 hours. Also a few pictures of the factory shoes. Bill [attachment=68900]P1040687.JPG[/attachment][attachment=68901]P1030755.JPG[/attachment][attachment=68902]P1010597.JPG[/attachment]
Sun, Sep 11, 2022 8:59 PM
D4Jim
Reply to 3J1Bill:
Nice looking 22 and parade ready!!
Cats Forever
Mon, Sep 12, 2022 1:58 AM
Reply to D4Jim:
rubber has a advantage too it wont skate on steel or slippery surfaces the same as the steel shoes.
Mon, Sep 12, 2022 1:00 PM
Claremontcat
Send a private message to Claremontcat
I've been looking for rubber track pads for my D2-5U, does anyone know a source?
Mon, Sep 12, 2022 9:27 PM
daron
Reply to Claremontcat:
Try 'John from Fresno' on this BBS.
Daron
Mon, Sep 12, 2022 11:38 PM
D2Fred
Send a private message to D2Fred
how do you think these pads would compare to the ones on my d2?( check tractor picture in my avatar) would they work with some modification?
Tue, Sep 13, 2022 8:41 PM
3J1Bill
Reply to D2Fred:
Fred, you would need a grouser pad to bolt on these. The factory ones you have would need new rubber molded on the shoes. Like my CAT TEN does. Bill [attachment=68939]tenwinch010.jpg[/attachment]
Sat, Sep 17, 2022 5:50 AM
