Root rake pics
Root rake pics
Showing 1 to 10 of 21 results
Pioneer1930
Send a private message to Pioneer1930
Hello Folks, Now that I have my D2 running well I am going through my Laplant blade and assembling the system. Does anyone out there have any pics of a factory or homebuilt root rake? I've gathered my materials and have looked online at some. I just wanted to see what you all have come up with. I want to avoid any mistakes or have some experienced insights before I weld it up. Thanks!
Thu, Dec 15, 2016 10:42 PM
Thank you received: 140
Hi, Pioneer1930.
Here is a video advertising a very good line of stick rakes.
https://www.youtube.com/watch?v=QNPLhEmcJGY
But I'm guessing that you don't want to build anything that elaborate for your D2? All I would suggest is that you make it a wider than the normal dozer blade 'cos sticks are not as heavy as dirt and make the section in front of the radiator and above the teeth from solid plate - 1/8" or better for a D2 - and close to as high as the top of the radiator - 'cos you can't what the sticks are doing in front of the radiator, at least until it's too late.
Just my 0.02..
Fri, Dec 16, 2016 12:03 AM
Pioneer1930
Hi, Pioneer1930.
Just my 0.02..
Thanks for the info, I have a very heavy duty grille guard and I planned on adding a section of expanded metal above my blade to help protect against rouge brush, thanks for the advice!
Fri, Dec 16, 2016 12:40 AM
Reply to Pioneer1930:
Hi, Pioneer 1930.
All I would add is, "NEVER trust a stick." There have been a HOST of reasons throughout mechanized history for this. LOL
Fri, Dec 16, 2016 12:49 AM
Hi, Pioneer 1930.
There was a fellow out East that posted a year or so ago that had a D2 (D4?) with a nice Root Rake setup in one of his photo's? I didn't save the picture as I thought it would be easy to go back to find if needed.
Fri, Dec 16, 2016 1:32 AM
mrsmackpaul
Reply to drujinin:
A lot of people made stick rakes that pivot about halfway up the side of the blade and pinned up for normal blade work and down for stick raking
Have tried looking Google for a picture
These were only ever used on small machines and for small amounts of work as the are the same width as the blade but seemed to work ok for what they were
Deas may have a photo of such a item or be able to explain it better than me
Paul
Fri, Dec 16, 2016 2:14 AM
Reply to mrsmackpaul:
Paul
Hi, Pioneer 1930.
The fold-up stick rakes that MrsMP mentioned really only work with straight dozers 'cos you needed the vertical end plates fo attach them to allow them to fold up or down. Basically, they were a piece of heavy steel angle that fitted across in front of and lapped under the cutting edge with rake teeth welded to the underside of the angle and arms extending up from each end to pivot points about 1/2-way up the sides of the blade, so the rake could be lifted up and pinned out the way for dirt work without having to completely remove the rake. I did see a couple many years ago that had a 4" or so RHS box section beam in place of the steel angle beam to carry the teeth and these seemed to be a more robust construction although somewhat heavier.
These rakes were pretty much a light duty substitute for a 'real rake' but they did work. Some people used to face up to a tree when they wanted to fold the rake up. They would lift the blade right up, tie the rake section to a branch in the tree the tree, and lower the blade to lift the rake up so that they could pin it in the 'up' position.
And, when raking, you still had the blade to help protect the radiator.
Hope this helps'
Fri, Dec 16, 2016 5:48 AM
mrsmackpaul
Hi, Pioneer 1930.
Hope this helps'
yep Deas thats the go only nice and lite I think it would be ideal for the D2 as they already are renowned for been a tad bit unstable back and forth when a blade is fitted
Paul
Fri, Dec 16, 2016 9:33 AM
Paul
Hi, MrsMP.
Yep, fore-n-aft stability has always been a trifle 'problematic' with D2s with dozer blades, although the larger front idler does make quite a difference - trubble being. I seem to remember it requires an extra link in the chain.
Fri, Dec 16, 2016 12:06 PM
old-iron-habit
Hi, MrsMP.
I seen a D2 a couple years ago with a rock box type counterweight connected to the drawbar and the winch mount holes. It was filled with concrete. It made a clean bumper on the back the way it was built. I took a picture as it was a clean install but I can't seem to find it now.
Fri, Dec 16, 2016 9:43 PM
Pioneer1930
Reply to old-iron-habit:
Nice, I didn't consider the counter weight issue. I do have a heavy duty spring it must have been replaced years back maybe due to the blade weight issue when It was installed, who knows but it is definatly not factory. I like the idea of a removable rock box at the hitch though. Thanks for the considerations..
Fri, Dec 16, 2016 10:41 PM
