Root rake for track loader
Showing 1 to 6 of 6 results
Cat951
Send a private message to Cat951
Hi,
I wanted to know if it is possible to apply to my CAT 951 a root rake.
Were mounted on these machines? Are productive with this equipment?
I was planning to make a quick application similar to those for the dozers but for crawler loader as my I did not find anything.
Do you have any information about this?
Sat, Oct 18, 2014 5:37 AM
BobPV15
Send a private message to BobPV15
Yes they were made by some after market suppliers. I have one for my 977L, they are good for making burn piles.
Sat, Oct 18, 2014 8:27 AM
Cat951
Reply to BobPV15:
Hello and thanks for the reply!
Since I come from you do not find anything like that, I was thinking to fabricate one, but made ​​like that of the dozer and fixed by two pins, that is to be applied in front of the bucket, it is possible for you?
Compared with the bucket, with the root rake strives more the loader?
Sat, Oct 18, 2014 2:54 PM
BobPV15
Reply to Cat951:
Yes you could make something that mounted to the front of the bucket. The one I have replaces the bucket and is quite heavy. I can take some pictures and send them to you, but it will be awhile before I am back to the property where the machine is at.
Sun, Oct 19, 2014 12:15 AM
Thank you received: 106
Reply to BobPV15:
Hi, Cat 951.
Yes, you can make a root rake for a track front end loader. I used one that chained to the bucket of a Cat 941. It was about 12 feet wide and the end 2 feet on each side was angled forward, something like a U-blade on a dozer, to better hold the sticks,roots, logs, etc., in front of the rake. This one was designed so that the teeth of the bucket fitted between the tines of the rake but did not extend down as far as the tines did. It was also designed so that the bucket was at about half-dump angle when the rake was standing vertical which allowed for some lifting of the load by rolling the bucket back, very handy when pushing a load of the side of a burn pile.
This rake also had solid 1/4" plate right across the front of the bucket to stop the bucket filling up with debris which could become pretty difficult to get out without removing the whole rake, not to mention that a bucket full of debris plus the weight of the rake would be pretty heavy on the front idlers.
Sun, Oct 19, 2014 4:38 AM
D4C Charlie
Send a private message to D4C Charlie
Hi, Cat 951.
I helped a friend make a pin on rake for a track loader. We made it for brush clearing and rock sorting. We were sifting river run for a certain size river stones and the rake did a great job just rake them up and roll the bucket back. Worked great for brush clearing and stacking or loading out. Do a general search for Mann brush rake for crawler loader and you will see how they are built. Good luck. Charlie
Sun, Oct 19, 2014 6:12 AM
Cat951
Reply to D4C Charlie:
Thanks to everyone for the valuable input!
I'm clean 120000m^2 of land, but maybe I'll use a shredder, because isn't very hard vegetation.
Tue, Oct 21, 2014 5:09 AM
