Roller specs ?? D4 7 series
Bellyman
Send a private message to Bellyman
Can someone tell me or Direct me to find Roller Specifications forĀ  D4 7U series dozer ? I need to replace , top rollers or rebuild two ?? Thanks to all , cheers RobB
Mon, Mar 7, 2022 8:00 AM
bursitis
join up and use the library. in it you will find instructions for rebuild conservation. the rollers can be welded or built up and reused
Mon, Mar 7, 2022 8:14 AM
Shaban1983
Send a private message to Shaban1983
Reply to bursitis:
Top carrier rollers generally don't bear much weight, I'd keep using them as long as they don't cause trouble and don't have visible damage and/or slop
Those top rollers on D4-7U are 9B-0562.
There are no direct replacement aftermarket ones, I think replacement is possible but from memory it's tricky, needs a new shaft pressed into the tower.
Also check this old thread:
https://www.acmoc.org/bb/discussion-d72/27068-non-current-undercarriage-dimensions
Wed, Mar 9, 2022 8:31 AM
