Rodger the Dachshund and master Bill - 1955 955 12A
Showing 1 to 9 of 9 results
Bill Glenn
Someone sent this picture to me…. Rodger the Dachshund and master Bill. Note the matching straw hats. Rodger is a real HIT at the tractor shows. Taken at Rough & Tumble August 2015. The 12A 955 is running really good
Mon, Oct 5, 2015 6:40 AM
I take it that the bearing you made and fitted is holding up well. Do you still have the D2? Great you have a pal that likes machines like Reggie did!
Mon, Oct 5, 2015 7:53 AM
Bill Glenn
Reply to dpendzic:
dpendzic, Ha! I had forgotten all about that bearing!!! Yes, it's doing Okay - 25 - 30 PSI (more when colder) Oh yes, still have the mighty D-2. I'll be using both this weekend
Mon, Oct 5, 2015 8:37 AM
chriscokid
Reply to Bill Glenn:
good to see you back on here. i enjoy seeing your pics on facebook.
Mon, Oct 5, 2015 5:14 PM
ronm
Reply to chriscokid:
I was wondering about that bearing too...I still think you were butt-lucky on that one, but hey, you can't argue with success!
Mon, Oct 5, 2015 8:30 PM
Reply to ronm:
I thought in the end, the Aluminum bearing made, didn't get used?
http://www.acmoc.org/bb/showthread.php?8836-Traxcavator-955-12A-–-polishing-the-crank-amp-rod-journals/page5
Mon, Oct 5, 2015 9:20 PM
Bill Glenn
Reply to drujinin:
Hold on a minute.... I'm confused myself.... You are correct - I did use the CAT bearing and not the Aluminum one that I made - it's been 8-9 years ago.... You guys have a memory like a steel trap - good for you!
Tue, Oct 6, 2015 8:57 AM
83Jim
Send a private message to 83Jim
Sorry Bill but I'm going with Roger on rocking the straw hat.
(Obviously I have spent too much time perusing the magazines while waiting for the Mrs. at the salon).
You only need two tools in life - WD-40 and Duct tape. If it doesn't move and should, use the WD-40 If it shouldn't move and does, use the duct tape.
Cat D4D 83J w 3304 PC engine, FOPS, s/t blade, D4F winch, air ride seat, "wobble" stick blade lever and D8H control panel
Cat 920 62K w 3304 PC engine, FOPS, 4 in 1 bucket
1995 Dodge Ram 2500 4x4 RCSB Cummins 5 speed
Thu, Oct 8, 2015 11:11 PM
oldtanker
Send a private message to oldtanker
Reply to 83Jim:
Which one is which? Or better yet which one is smarter????
Rick
Fri, Oct 9, 2015 12:31 AM
mrsmackpaul
Reply to oldtanker:
Rick
good old Rodger he's quite the famous dog on face book looks like he's master of all things just about
Paul
Fri, Oct 9, 2015 1:32 PM
