Road Grader Weight
Road Grader Weight
Gas Patch
Send a private message to Gas Patch
Can anyone tell me the difference in the weight of an Auto Patrol 10 tandem drive and an Allis Chalmers model "D" tandem drive?
Thanks in advance.
Fri, Oct 15, 2010 11:43 PM
chriscokid
here is the cat grader weights
http://www.chriscomachinery.com/Graders.htm
Auto Patrol 10 tandem 16350 #
Allis Model D weight 8500 #
Sat, Oct 16, 2010 7:59 AM
Thank you received: 34
Reply to chriscokid:
Hi, Gas Patch.
From Chrisco's chart, there apparently would not be a lot of difference. I have operated a couple AC DD's and they were generally reckoned to be around 8 long tons, give or take a bit - a long ton is 2,240 # - so possibly the DD might be slightly heavier by around maybe 1,600 - 1,800 #.
Hope this helps.
Sat, Oct 16, 2010 1:05 PM
chriscokid
Hi, Gas Patch.
Hope this helps.
Model DD Allis 1961-1971 weight 9359# has D-262 engine(buda Diesel) 58HP
if you are looking for a compatiable grader based on weight here are two made by allis listed below:
Model 42T Allis speed patrol 1936-1940 tandem Gas 42HP, weight 15648#
Model BD Allis Grader 1948-1949 GM 2-71 Diesel weight 17300#
Sat, Oct 16, 2010 6:21 PM
Gas Patch
Thanks to both of you for the information.
This is what I was looking for.
Sun, Oct 17, 2010 6:13 PM
