Ripper hydraulic valve
cr
Send a private message to cr
Thank you received: 25
Wed, Apr 8, 2009 11:18 AM
ag-mike
according to cat tool bar manuals chisels and subsoilers must operate in float, even when gauge wheels are used. i'd say your case the bigger the machine and hd built tool etc and only running 8-12 inches go for it. flat land work will keep it close to constant depth.
Wed, Apr 8, 2009 9:09 PM
Thank you received: 64
Reply to ag-mike:
The D4E for example...does not use a float position valve for the parallel linkage ripper. I don't believe you would want that feature as the ripper/scarifier teeth would bury itself to the hilt.
My 3-pt on the D4 utilizes the the single valve #44 with float valve but I seldom use the float feature.
Wed, Apr 8, 2009 10:44 PM
The Cat scarifier on the HT4 is connected to the non float valve of the two valve #44 system and is controlled by a "transflo valve" to isolate it from the loader cylinders.
Thu, Apr 9, 2009 11:00 AM
