Right blade?
Right blade?
WILSON
Send a private message to WILSON
I have a 1940 d-4 7j with a cat 6w9189 wide blade. Is this original? I was told cat did not make there own blades untill after wwii.
Tue, Oct 9, 2012 3:56 AM
Thank you received: 39
Yes, Cat was late in supplying their own blades but they could be retro mounted to the earlier models. Your 6W9189 is more likely to be for the #44 hydraulic control. Blade numbers would typically be 6Fxxxx number for the wide (angle) blade. A couple of pictures would help solve identification.
Tue, Oct 9, 2012 9:34 AM
KCB
Send a private message to KCB
As usual, OM is right. S/N 6W9189 is for a No. 44 Hydraulic Unit, single valve, built 1951.
Tue, Oct 9, 2012 10:36 AM
