Ridge Reamer
Ridge Reamer
Showing 1 to 7 of 7 results
abram
Send a private message to abram
hello all, i'm still in the process of overhauling a d2, had a question though...i believe the pistons and rods are removed from the bottom of the engine correct? if this is the case is it necessary to remove the ridge???
3J5 D2
Sat, Dec 6, 2008 10:09 AM
New rings on a piston with proper ring groove clearance, (especially the top groove) will likely hit the ridge and be damaged on the first run.
The old rings had worn down and matched the ridge they created, the new ones probably won't.
Sat, Dec 6, 2008 10:43 AM
Sasquatch
Thank you received: 5
Yes, the pistons and rods come out the bottom.
On my 5U D2 I was unable to cut the ridges with any of my reamers due to the extremely hard liners. I ended up honing them down with an adjustable circumference hone. It also helped ensure the liners ended up perfectly round when I was finished. Although when you're honing you need to make sure you don't have to take so much material out that you exceed specs.
Sat, Dec 6, 2008 11:14 AM
Reply to Sasquatch:
You can get the seals for the sleeves cheap through CAT. I say pull the sleeves and clean the cooling jacket. Mine had rust and dirt buildup halfway up the sleeves which caused cylinders 3 and 4 to run hot. Plus your pony will not warm the main properly because its passages to the main will be plugged up which will make the pony run hot also.
Sat, Dec 6, 2008 6:30 PM
11A933
Send a private message to 11A933
Reply to drujinin:
I had the same problem with my old 933 the block was full of rust and curd,we took the liners out to clean it, luckliy the seat and seal area were good, some time back someone on here posted a link to a short video showing Cat parts been reclaimed during WWII, if you don't blink your eyes you will see the ridge cutting and etching of a liner.
Andy
http://uk.youtube.com/watch?v=H4X-DnIbMMs
Sun, Dec 7, 2008 12:46 AM
gwhdiesel75
Reply to 11A933:
Andy
11A933 - the film was excellent! GWH
Sun, Dec 7, 2008 1:07 AM
Mike Mahler
Send a private message to Mike Mahler
Reply to gwhdiesel75:
I second that! Excellent!!
My services shown at www.myspace.com/vintageengine
Sun, Dec 7, 2008 1:32 AM
Sasquatch
Reply to Mike Mahler:
11A933, a big thanks from me too for posting the link to that video, very interesting to watch. It's a shame so many of the components on machines today are built to be disposable instead of rebuildable. It makes us pretty dependent on a constant parts supply.
Sun, Dec 7, 2008 2:36 AM
