Revitalize! (D2 pony)
Showing 1 to 10 of 22 results
Jerk
Send a private message to Jerk
Me thinks it's time to stuff it. I am finally done "revitalizing" my pony. I'm not calling it a rebuild since I got lucky and didn't actually have to replace anything internally. She's ported, polished, and performed some race car magic inside and managed to keep everything within acceptable tolerance. It's a little loose but should be just fine. Maybe I'll get to push some snow with the old girl yet.
Thu, Mar 7, 2019 6:04 AM
Almost thought the gas valve was on wrong, its just missing the valve.
Thu, Mar 7, 2019 6:56 AM
d2gary
That looks pretty sweet
Thu, Mar 7, 2019 8:28 AM
Jerk
I figure I'll be safe and wait till the pony is in the tractor to install the valve. My luck I'd destroy it somehow during install.
Thu, Mar 7, 2019 8:49 AM
Jerk
Reply to d2gary:
Thanks dude. I just hope it runs as good as it looks. Wish I had the money for different paint tho. I don't like the bright yellow but I had a couple cans laying around so what the heck. Better than rust.
Thu, Mar 7, 2019 8:53 AM
In the 4th pic I noticed there is a plug where the crankcase breather should go, to the bottom right of the mag, just wondered if you knew about that?
Thu, Mar 7, 2019 9:26 PM
Jerk
I had no clue about that. Looks like another item to get from General next time I go to Boise. Good lookin out holmes. Thank you
Fri, Mar 8, 2019 2:43 AM
Reply to Jerk:
"Notta problem sir", "oh just more thing, here's the part # 2F3850, oh and dont forget the nut, 3F4343, thats all"
Fri, Mar 8, 2019 2:58 AM
Jerk
That breather would be a neat little project for my lathe if it wasn't in a million pieces scattered about. I guess for now I'll just rig up a breather from a differential or something. Think I'll sit with my coffee, maybe twist up a rooter and "think" on it for a bit.
Fri, Mar 8, 2019 3:20 AM
Reply to Jerk:
Florin Tractor Parts has them.
Fri, Mar 8, 2019 4:42 AM
STEPHEN
Reply to Jerk:
Not similar at all. The correct one allows excess fuel to leak out, but keeps air from freely entering the manifold ( that would make it run lean) it also has a felt pad filter to keep dirt out.
Fri, Mar 8, 2019 7:16 AM
