Reverse fan on 17a
Reverse fan on 17a
dan83
Send a private message to dan83
Hello I'm wondering if I can flip the fan on my 17a7075 its sucking right now it runs at proper temp just blowing more heat at me than nessasary thanks dan
Thu, Jul 23, 2015 5:25 PM
Thank you received: 130
Hi, Dan.
Reversing the fan does not give the same air flow that working the designed way does. You can get 'blower' fans that are designed to push air out through the front of the radiator and you can also get reversible fans where the blades are flat and can be turned from sucking to blowing.
Hope this helps.
Thu, Jul 23, 2015 6:12 PM
rmyram
reversible fans are fairly popular in canada. check to see if your 17a already has one installed. you can reverse the fan pitch and use it as a blower fan in the summer, and a sucker fan in the winter to help keep you warm. there is usually a special tool you are supposed to be able to slide through a hole in the hardnose, and spin the blades around after pushing them in against a spring. i had the hood off my 9u and managed to spin all the fan blades around using my hands a pair of water pump pliers (channel locks)
Thu, Jul 23, 2015 9:35 PM
Thank you received: 60
Reply to rmyram:
Blower fan part # is 3H6868.
Says they have one here....
http://www.machinerytrader.com/list/partssearch.aspx?partnum=3H6868
Also the matching guard 5H2865
http://www.machinerytrader.com/list/partssearch.aspx?PartNum=5H2865&btnPartSearch=Search&PST=Starts
Thu, Jul 23, 2015 10:38 PM
Too bad Huber went out of business. I got them on several my tractors. All these cozy cabs now with the stereo, ac, heat, pressurized, soundproof, uv ray protection, filtered air, probably fart smell proof too, oh well at least the operator can go home smelling all pretty still for the wifey poo. lol
Fri, Jul 24, 2015 8:21 AM
dan83
Ha thanks im ok with the heat I would have flipped it if it was that easy but good to know thanks she's working great
Fri, Jul 24, 2015 5:00 PM
Bruce P
Thank you received: 33
Reply to dan83:
Good looking 17A you got there. Enjoy it!
Bruce P
Fri, Jul 24, 2015 7:38 PM
mrsmackpaul
Reply to Bruce P:
Bruce P
[quote="Bruce P"]Good looking 17A you got there. Enjoy it!
Bruce P[/quote]
It sure is good looker Bruce
Paul
Sat, Jul 25, 2015 5:26 AM
mog5858
Reply to mrsmackpaul:
Bruce P[/quote]
Paul
nice looking pic looks like she working for her diesel. keep up the good work
Sat, Jul 25, 2015 9:10 PM
