Restoring New Cat Hauler
Showing 1 to 7 of 7 results
rustrunner
Send a private message to rustrunner
Decided to start the restoration on my new Cat Hauler.
1953 Dodge B-4-KA truck and 10 Ton Fruehauf Trailer.
Truck has 265 engine with twin carbs. Also has both Air and Vacuum brakes for the trailer. I figure 4 MPG empty, and 3 MPG loaded.
Dan
[attachment=18688]Trailer.jpg[/attachment][attachment=18689]Truck.jpg[/attachment][attachment=18690]53 dodge truck and 39 dodge car 239.jpg[/attachment]
Fri, Jul 26, 2013 3:12 AM
rustyfender
Send a private message to rustyfender
awesome. makes my 75 d 800 tractor not so interesting!
Fri, Jul 26, 2013 3:23 AM
Oil Slick
Reply to rustyfender:
If the gas engine is bad or needs money, a Cummins 12 valve would fit nice and probably out work the gas engine while getting conciderable better mileage.
Fri, Jul 26, 2013 3:42 AM
rustyfender
Reply to Oil Slick:
yes, but I will continue to dump gas in the old 413 until it dies, BUT should be rustling up a 12 valve for future use. I suppose the 6 speed tranny would work fine off the Cummins for my application.( which is a semi retired excavating contractor)
Fri, Jul 26, 2013 4:44 AM
rustrunner
Orginal, Orginal, Orginal
Going back Gas 265 twin carb, Air over Hyd truck brakes, and both Vacuum and Air trailer brakes. Will never use vacuum trailer brakes, but will have them on truck. Trailer will have Air brakes as it does now.
Vacuum 2 speed axle and the works. Will convert to 12 volt.
Fri, Jul 26, 2013 5:33 AM
old-iron-habit
Reply to rustrunner:
Does the axillary gas tank in the first picture stay? LOL. Have fun with it. It will be cool when done.
Fri, Jul 26, 2013 6:40 AM
mike in ca
Send a private message to mike in ca
Reply to old-iron-habit:
Nice truck, it should be a fun project. I like that you are keeping it original. I have a 1952 B-3-GA 152 but it has a flat bed for hauling hay so I don't think it will ever have a cat on the back.
Mike
RD4 4G2183
Sat, Jul 27, 2013 10:39 AM
acat65
Send a private message to acat65
Reply to mike in ca:
I would advise converting to straight air for truck, I am sure the parts could be found and would be safer and more reliable,and put spring brakes for parking etc.This isnt going to be an economical restoration,so I would consiner a cat diesel power plant.A 3176 would be a good choice, Gene
Sat, Jul 27, 2013 9:02 PM
