would love to have one of these machines. Have a friend that has one all restored, may have some parts
Looks like Jerry's havin Subway! lol
Gary
Gary
[quote="ROME/KG"]Looks like Jerry's havin Subway! lol
Gary[/quote]
Yea it was a cold cut special...LOL!
Nice looking project Eric,would like to have one of them.If it ends up like all your other projects it will be a first class project.Good luck.Mike
MOG5858 has one he rescued from that floodwater a year or so ago. He should be able to help out with the tire size. Have not heard from him for a couple weeks. Might be super busy at work.
The drawbar looks like it has never had a pin in it.
Dumb question of the day,how much of a 8u,9u back end is the same as the B's?????Much of it looks very similar if not the same castings as used on the earlier tractor.Would assume the gears would be different,but I don't know.
Thirty years ago I got a big surprise when I learned 3T D7 and 9U D6 had the same steering clutch ,brakes,and steering boaster.So if it looks close I ask.
[quote="Ray54"]Dumb question of the day,how much of a 8u,9u back end is the same as the B's?????Much of it looks very similar if not the same castings as used on the earlier tractor.Would assume the gears would be different,but I don't know.
Thirty years ago I got a big surprise when I learned 3T D7 and 9U D6 had the same steering clutch ,brakes,and steering boaster.So if it looks close I ask.[/quote]
good question once i get a parts book i will compare part numbers to see what is the same and what is not.
Bull gears and pinions are different in 9u and D6B. Transmissions are different; mainly due to pinion brgs. BUT the gears may be the same; have never checked the gear part numbers.
