Requesting Comments on a D-7G Series
Paso Bob
I have been looking for a larger dozer. I'd really like to buy a 46A in decent shape but haven't been able to find one. I going to take a look at a D-7G and wondered if anyone had any positive or negative comments about that particular series. The one I'm going to look at has close to 7,000 hours. The tractor I will buy will only get used 100 hours a per year or less. Thanks in advance.
Tue, Feb 25, 2020 11:38 AM
Thank you received: 140
Hi, Paso Bob.
I didn't have a lot to do with them but I didn't see a lot of them broken down either. They seemed to me to be a pretty sold tractor. They did seem to be better balanced than the earlier F series which were a little light on the front with the first of the 6-bangers in them.
Tue, Feb 25, 2020 8:04 PM
Hi, Paso Bob.
Love the D7G! easy to maintain, built heavy, 7/8" roller bolts instead of 3/4". 3306 is a great motor. Find out if you can, records. With that many hours the turbo may need a new cartridge. If you can check magnetic filters, oil colors/levels, cut filters open/check between pleats, check for growling noises/trans/final drives, pump whining or howling, chattering noise in hyd tank, ticking noise from exhaust manifold leaks. And of coarse basic undercarriage wear. I really like the combined steering and braking.
Tue, Feb 25, 2020 10:06 PM
OZPHIL2
Send a private message to OZPHIL2
Hi Bob,
Just to confuse the issue since you mentioned you has a soft spot for a 46A, have you considered an ex-military 75E series D7E or 61G series F. Some of those you'll find have less than a couple of thousand hrs on them and are well maintained, maybe even hrs in the hundreds. Whereas a 46A will be well flogged out as I'm sure you know. There's probably thousands of ex-mil 75E's /61G's around. 180/200 hp, turbo engine, OROPS, EROPS cabs, some have rippers, many have a winch.There will be many that have never left a base in USA and with super low hrs.
Here's a mob of them shipping out in Iraq, same thing. I love the way the Marine Corps gitter-done when it comes to moving out heavy gear.
https://www.youtube.com/watch?v=sJervtj8YEM
Cheers
Phil
Wed, Feb 26, 2020 10:29 AM
