replacing the Brake Liners on 955-12A
Showing 1 to 10 of 14 results
rditz
Send a private message to rditz
I have the service manual,, but I am posting to ask opinions from those that have experience actually doing the work.
I have a 955-12A and recently turning the machine is getting more difficult. I am considering changing the liners and wanted to know, how hard is it to do this without removing the seat and fuel tank?? there are two procedures in the manual, the second of which is to do the replacement through the inspection covers on the rear housing...
Thoughts???
if i do it the other way and remove the seat, fuel tank, etc... I will also have to remove the hydraulic reservoir and associated equipment.... a big job onto itself..
thanks in advance for your comments.
rod
Tue, Jul 24, 2012 12:17 AM
catsilver
The most difficult bit will be removing the anchor pins through the case ahead of the final drive, clean the threads out in them and see if they will move first.
Tue, Jul 24, 2012 3:52 AM
rditz
Reply to catsilver:
Thanks I am trying to source a set of good bands before I open anything up... i have has good luck with this tractor getting things apart as I have needed to, so I am optimistic that this will go well...
rod
Tue, Jul 24, 2012 8:21 PM
rigandig
Send a private message to rigandig
Reply to rditz:
rod
Rod,
I have a set of bands, Tag on them says 4K1327A. Don't know if they are what you are looking for. Have been on the shelf here in my storage trailer for quite a while.
Riggy
Wed, Jul 25, 2012 10:33 PM
rditz
Reply to rigandig:
Rod,
Riggy
Thanks Riggy, I will check my parts book at home and confimr the part number..
what would you want for them, if they are correct for my machine?
rod
Wed, Jul 25, 2012 10:49 PM
Reply to rditz:
rod
I show 4K1327 to be a band assy. with linnings + 4K1327, 3A2254, 4K1330 which I assume are the band segments.......however, these numbers do not match the segments shown in the 12A parts manual.
Wed, Jul 25, 2012 11:54 PM
gemdozer
Thank you received: 25
The 4k1327 brake band are for 955h-k and not fit on 955-12a
Thu, Jul 26, 2012 12:23 AM
BillWalter
Reply to gemdozer:
Be prepared tp swear a lot. It is one heck of a job. I hope you're young and can twist your arms and hands in to some unconventional positions. But when the job is finished, you'll have a warm feeling of Accomplishment. Good Luck!!!
Thu, Jul 26, 2012 1:54 AM
rditz
Reply to BillWalter:
thanks for the words of encouragement Bill.. I am assuming that you speak from experience?? is this a weeknd job or longer.
rod
Thu, Jul 26, 2012 3:48 AM
rditz
Reply to gemdozer:
hector, you were going to check to see if you had a set of linings...
I checked my parts book and the "Lining Group" has a part number of 5H6031 and is said to consist of complete set of linings & rivets for one brake.
i checked a web site for cross reference of the part number and the matches are some variant of the one above.
thanks
rod
Thu, Jul 26, 2012 7:07 PM
gemdozer
Reply to rditz:
thanks
rod
I send you a email about a brake band set with linning and #5h6031 is 6 pads linning for 1 brake band ass and I do't have these linnings.sorry
Thu, Jul 26, 2012 11:53 PM
