[quote="rrrepsher"]I have a 80's model D3B dozer. The starter is locked up on it. How many bolts hold the starter to the bell housing? Also, can the starter be removed without taking the belly pan off?
When the starter button is pushed, the starter/solenoid just clicks repeatly until you let off the button. I originally thought that it might be the solenoid. I disconnected the starter and confirmed that the solenoid works correctly. I then took a wrench and manually jumped across the solenoid. The starter did not spin. This leads me to think that the starter is lockup up.
I look forward to your replies[/quote]
3 bolts, check your battery and wiring first,d-3 is known for wiring issues.
Good luck
Bob
Before you pull the starter, reach in and turn the fan (and engine) a bit and try the starter again. Sometimes what happens is that the teeth won't engage, what my dad used to call "hitting dead center". Not a common occurrence but I've seen it happen clear back to when I was messing with Ford flathead engines when I was a kid.
Good point "ol grump"....starter drive has to engage flywheel to make the cranking contacts.
Still remember "Rocking the old V-8"s" when you had the misfortune of downhill diagonal parking against a curb and the starter drive jamed......
