Replacement pump for Front Hydraulic Control Model 41 - 14.5 gpm
Showing 1 to 10 of 11 results
rjstumm
Send a private message to rjstumm
The hydraulic pump in the Model 41 front mounted (single valve) control unit on my D2 4U is well worn and lacks pressure. I believe that the Cat part number for the entire pump is 1H1340.
I have been advised that parts to refurbish the pump are very rare (and expensive). Has anyone had experience fitting an alternative and more modern pump? Something that will fit inside the oil resevoir tank. The current pump has a splined shaft. However, finding a similar capacity vane pump which will fit into the tank is my first priority.
Regards, Robert
Mon, Aug 27, 2012 3:58 PM
Seems to be several interchange models. Get with a Vickers pump dealer and see what you can work out.
http://www.tpaktopc.net/cgi-bin/Cat_Part/Cat_Part.cgi?findPartNum=1H1340
Mon, Aug 27, 2012 10:08 PM
Gary Morisoli
Send a private message to Gary Morisoli
Try Knight Hawk Supply. I was able to get parts for my 41 pump from them. Good Luck, Gary http://knighthawksupply.com/vicpistonpvb10.htm
Tue, Aug 28, 2012 1:47 AM
rjstumm
Reply to Gary Morisoli:
Old Magnet and Gary,
Thank you both very much for your quick replies and for the supplier leads that you have given. I will now follow up those leads.
Regards, Robert
Tue, Aug 28, 2012 3:19 AM
B4D2
Reply to rjstumm:
Regards, Robert
[quote="rjstumm"]Old Magnet and Gary,
Regards, Robert[/quote]
Let us know what you find. I know a few other guys with #41 units in need of some TLC.
Tue, Aug 28, 2012 3:38 AM
rjstumm
Reply to B4D2:
Yes B4D2, I will let you know how successful I am in replacing the pump.
Rgeards,
Robert
Tue, Aug 28, 2012 3:34 PM
rjstumm
Reply to rjstumm:
Rgeards,
Robert
Old Magnet, Gary, B4D2 and others,
I have been able to refurbish the hydraulic pump in the Model 41 front mounted unit on my D2 by purchasing a cartridge kit. I bought this from Pro-Active Fluid Power in Michigan (www.proactivefluidpower.com). I found the people there to be very knowledgeable and extremely helpful. Their part number is : 912067 Vickers Cartridge Kit.
The part is an exact replacement for the one that was in my pump. However, the refurbished pump doesn't have any more pressure that the old pump had, so there is obviously a problem in the hydraulic valve unit which is bolted directly to the discharge port on the pump. I have pulled this apart and reassembled it several times and I can't see anything out of place. There seems to be three valves in total. One is obviously the releif valve and this is in its own separate casting bolted to the top of the valve unit. The other two valves are side by side within the main body of the valve unit block. Each of these has what seems to me to be a very weak spring behind it to hold it against its seat. The springs look too weak to be of any use any my suspicion is that they are not original.
Is anyone able to offer advice about how stiff these springs should be from the description I have given. Also, any advice on what might be causing the low pressure problem - the rams wou't lift the blade and with the rams disconnected from the blade and they are extended to the end of their stroke and the hydraulic pump comes under full load, it creates so little load that the diesel hardly changes note. Any suggestions?
Thanks. Robert
Mon, Nov 19, 2012 5:03 PM
7upuller
Reply to rjstumm:
Thanks. Robert
Hey Rjstumm,
Have you done a pressure test on the pump? It could be that the problem is in the cylinders and not the pump.
Mon, Nov 19, 2012 9:30 PM
Reply to 7upuller:
Hey Rjstumm,
If your running Cat dozer hydraulic cylinders they have internal end of stroke relief valves. (could also be source of leakage). Need to disconnect and cap lines to get a good dead head pump pressure check.
Mon, Nov 19, 2012 11:06 PM
rjstumm
Thanks for this tip. I have disconnected the rams and plugged the lines to and from the pump and the result is still the same - the diesel hardly changes note.
A friend has suggested that the vanes in the pump need back pressure from the outlet side of the pump to make them push out against the swept surface of the chamber that the vane hub turns in in order for the pump to operate properly. That is why I was wondering if the two valves with the weak springs that I described had anything to do with the problem. Anyway, I have to dismantle it again so I will try and study its function and see if I can understand why it is not working.
Thanks for your suggestions. Robert
Tue, Nov 20, 2012 2:46 AM
Reply to rjstumm:
What weight oil are you using? Not uncommon that pressure will not build right away if oil is thick and cold....that's the purpose of using the vane pump....reduces cold starting load. Let it warm up some and see what happens. Takes a combination of centrifugal force (rev it up) and reduced viscosity to get pumping.
Tue, Nov 20, 2012 4:20 AM
