Repaint CAT lettering
Showing 1 to 9 of 9 results
davidbrodhead
Send a private message to davidbrodhead
I'm trying to sharpen up the look of my D2.Anyone have any ideas on how best to repaint the the black raised metal names on the sheet metal?An example would be the CATERPILLAR on the front of the radiator.Obviously one way is by hand using a small artists brush.
Thu, Aug 20, 2009 6:25 AM
bruce oz
Thank you received: 20
hello David , i have used a small felt tip brush on them ,has square edges to do the sides and no brush marks on the yellow ,you can get them from craft shop ,bruce oz
[img]http://news.thomasnet.com/images/large/486/486648.jpg[/img]
Thu, Aug 20, 2009 6:52 AM
B4D2
Reply to bruce oz:
A great trick is to use the filter off a cigarette. Dab-dab-dab. I would suggest the cig be un-smoked, so as not to pollute the paint with all of those nasty chemicals. (I am not a smoker, can you tell?)😄
Thu, Aug 20, 2009 7:42 AM
chugwater crawlers
Reply to bruce oz:
We use a small hard rubber roller from Home Depot. It's not a paint roller. I think it's for linoleum. Works great!
Thu, Aug 20, 2009 7:43 AM
STEPHEN
Reply to chugwater crawlers:
some of the hard rubber rollers are used for spreading ink on the old fashion type printing presses, they are called brayers sp?
Thu, Aug 20, 2009 2:25 PM
side-seat
Thank you received: 8
Reply to STEPHEN:
I've used my finger to dab the paint on
Thu, Aug 20, 2009 8:04 PM
Arthropod
Send a private message to Arthropod
Reply to side-seat:
I used a small artist paintbrush to paint the front letters and the whole time was thinking "There has got to be a better way". I am going to find and try the rubber roller method.
Fri, Aug 21, 2009 12:03 AM
powergiant
Send a private message to powergiant
Reply to Arthropod:
One Shot paint and the finger works very good.
I've done the foam, and small brushes. At least for raised cast letters nothing comes close once you get a feel for it. Just keep a wipe rag handy between dips.
Fri, Aug 21, 2009 3:27 AM
terrywelch_archive
I use the foam brushes most the time. I also use my Quills(a sign painters make of brush) and One Shot for none raised surfaces. Quills pull very nice in curves. Red Sable is a good lettering brush also.
Terry
Fri, Aug 21, 2009 5:53 AM
Tractorboy1
Send a private message to Tractorboy1
Reply to terrywelch_archive:
Terry
I have a D2 3j with the metal name plates. I have recently repainted mine, and what I did was go down to Wallmart. In their "art section" pick up a paint pen, they come in various colors, and in no time I had all the lettering finished. Best of all the price was right.......they're not expensive.😊
Good luck,
Mike
Fri, Aug 21, 2009 12:33 PM
Earlcoate Charity Open Day
