Removing TOUGH grease
Showing 1 to 10 of 12 results
Grader Dude
Send a private message to Grader Dude
I am working on getting the grease off my 12E so I can shoot some fresh paint on it, I have gotten much of it off by scraping the majority then a pressure washer and some degreasers. However some of the stuff I cant get off, namely the gear oil that has been running out of the main boxes in front of the cab. Is there some trick to getting all this junk off?
Sat, Oct 29, 2011 12:55 AM
chriscokid
If it is really caked on dry hard greese oil and dirt, I have found an air operated needle scaler to work well.
Here is the steps I do.
I soak it down with degreeser,
Steam Clean it
Blow off with compressed air
use needle scaler
Wipe down with more degreaser
Prime and then paint.
Sat, Oct 29, 2011 1:21 AM
lil cat mec
Send a private message to lil cat mec
sometimes i use a torch and a wire brush.... works wonders... and it aslo gets the old paint off... however if there is anything flamable or rubber or anything that can melt or burn this might not be an option...
i may only be 16 but i've learned some nice tricks from the old geezers😊
(not trying to offend anyone lol)
1935 CAT 22 2F4455W
1990 CAT D6H 4GG04120
2012 CAT 272C RED02823
1971? CAT 951B 86J01212
ronm
Reply to lil cat mec:
Easy-off oven cleaner-let it sit a while & hit it w/the pressure washer. Sometimes that old hard crap just takes lots of elbow grease...👋
Sat, Oct 29, 2011 2:00 AM
[quote="lil cat mec"]sometimes i use a torch and a wire brush.... works wonders... and it aslo gets the old paint off... however if there is anything flamable or rubber or anything that can melt or burn this might not be an option...
(not trying to offend anyone lol)[/quote]
Hey Dude---no offense taken! I have always found out in my 66 years you can always learn something from anybody who has taken a different look at things. 👍
Now--back in my old days when wood boats with many coats of paints were very common we would use a white gas blow torch to blister the paint and scrape clean the whole hull of the boat---i would suspect it would work better on steel! 😊
Sat, Oct 29, 2011 3:08 AM
Cysco
Reply to dpendzic:
I have found using a steam cleaner, coarse wire brush on a 4 1/2" Bosch angle grinder then steam cleaning again will get the majority of grease,oil and a good bit of the old paint.
Just my thoughts........
Have a good day.....Bill
Sat, Oct 29, 2011 4:49 AM
zootownjeepguy
You gotta be careful though, that old grease is still pretty Flamable. I use the old brush-on paint stripper (like oven cleaner but thicker and cheaper). Brush it on, keep it wet and just let it soak for a while. Sometimes it helps to scrape the heavy layers off with a putty knife as it's soaking. I'll even use the stripper before sandblasting, it really helps to loosen up all those layers of old, petrified paint.
BTW, I consider myself a "Junior Geezer" 😆😆
Rich Salvaggio
D2 5U9917
Sat, Oct 29, 2011 5:15 AM
ol Grump
Reply to zootownjeepguy:
I've been using some stuff called Crud Cutter from Bi Mart. Spray it on and let it sit for an hour or so, then hit it with the pressure washer. Seems to work well on old grease/oil but sometimes takes more than one application where it's really caked on. I used it on the knockerbox in the cab of the 12E and found the only drawback was the sharp odor. .had me sneezin' my fool head off for a few minutes😆
Sat, Oct 29, 2011 7:49 PM
mdirtycreek
Send a private message to mdirtycreek
Reply to ol Grump:
Diesel fuel will soften that crud also,but if you are going to paint,diesel leaves a whole new problem.
Sun, Oct 30, 2011 6:42 PM
Julian
Send a private message to Julian
Reply to mdirtycreek:
I've found my small pneumatic hammer to be good, use a blade chisel in the thing and at an angle so that it works as a powered scraper. Obviously it's best used on thicker cast components and not steel sheet.
Julian.
D47J5052
Sun, Oct 30, 2011 10:56 PM
Lance Jones
Reply to Julian:
Julian.
We have found the Hot diesel fired Pressure cleaner the Quickest and easiest Way to get that Crud off. They are usually readily available to hire , That real bad stuff , usually around Rollers and track frames can take a little while , You need to let steam soften it and then blow it off.and inside frames which You can't directly get at , just steam area for awhile and then you can get it of with scrapper or Knife as the steam will soften it . A old curved skinning knife is a great weapon when cleaning inside Track Frames . You need a 2500-3000PSI cold cleaner to come anywhere near a 2000-2500 psi Hot gun and will still take a lot more time LJ
Mon, Oct 31, 2011 12:41 AM
| Kingaroy, Queensland
