Removing D2 trunion pins
Showing 1 to 10 of 12 results
bcwayne
Looking for ideas how to remove stubborn trunion pins... I bought this dozer a couple of years ago... the master clutch and pony pinion were rusted solid from sitting for years with water in the bell housing... that's all fixed now, and I would like to remove the blade in order to make track removal and reinstallation easier for a pin and bushing turn.
No doubt it's been many years since the trunion pins were removed. On one side the threads that would be used to push them out are all bugger up, on the other side the pusher bolts have been broken of by someone else's attempt to remove them.
I tried pounding wedges between the pin face and the housing starting with a putty knife, then screwdriver tip to no avail... tried to get them to rotate by bouncing on the end of a 36'' pipe wrench,no go...
These are way tight... anyone face this before and have a solution to share ??? Thanks, Wayne[attachment=32476]IMG_0732.jpg[/attachment][attachment=32473]IMG_0729.jpg[/attachment][attachment=32477]IMG_0733.jpg[/attachment][attachment=32474]IMG_0730.jpg[/attachment][attachment=32475]IMG_0731.jpg[/attachment]
Tue, Dec 8, 2015 7:17 AM
STEPHEN
Dynamite!, well after you spend three days working on them you will be ready to blow it to hell. You should try driving them back in with a sledge hammer, just the vibrations will help break up the rust. Even if you get them started out with the screws, keep tapping the face with a hammer alternating with the extracting screws. Failing all else you could drill and tap the center for a large screw and attach a puller. Or weld a 1" bolt on center and pull that way. I just got my pins out three days ago with the hammer technique.
Tue, Dec 8, 2015 8:28 AM
leon
Send a private message to leon
Reply to STEPHEN:
You can apply muraitic acid liberally to rusted parts for a couple days, cover with rags to keep it wet,[acid works
quit well on rusted parts,use caution when applying],or a massive amount of heat with two rose bud torches while hammering and prying.
leon
Tue, Dec 8, 2015 10:21 AM
Diesel Powered
Send a private message to Diesel Powered
Reply to STEPHEN:
Looks like a big air hammer or large hammer drill (just shy of a full blown jack hammer), with a chisel bit, might help. Work it in from the side to spread it (essentially what you were doing, but on steroids), rotate it, etc. They're cheap to rent if you can't find one to borrow.
Not sure what kind of time frame you're looking at, but you could possibly custom cut something like a 1 gallon plastic jug to use as a soaking tub. Cut the top off and cut the remaining part in half vertically (and a notch where the blade arm is), then use some good caulking to secure it to the machine and around the blade arm. After that cures, fill it with your favorite loose juice (acetone/atf, etc) and let it think about it for a while.
Tue, Dec 8, 2015 10:59 AM
STEPHEN
Reply to Diesel Powered:
On the threads that are messed up, tap them oversize, you can weld them up and fix them later, on the bolts that are broken, extract them, chase with a tap. In all cases, when using threaded holes & jacking bolts make sure that the threads are clean, and apply antisieze to the threads liberally. It will keep the bolts from seizing and wringing off. It goes without saying that you need to use a grade 8 bolt, or higher.
Tue, Dec 8, 2015 12:48 PM
Cysco
Reply to STEPHEN:
Thought I would post a couple picture of what it looks like behind the flange when I got my pins out. I found an awful lot of dry, hard packed grease,dirt and rust when I finally pried one side out. The other side , which had the broke bushing, came out easily. I had new bushings made and all is good now. Good luck with your project.
Have a good day......Bill
Tue, Dec 8, 2015 5:06 PM
Gregness
Reply to Cysco:
Well, this is very strange, at least to me!
When I inherited my D2 one trunion pin was held in place by a chunk of rebar that was welded over it, as the bolts were stripped out; on the other side only two bolts were left. Both sides popped right out, and I don't recall a time when Grandpa ever had the blade off. One of the pins appeared to be the wrong size, and I ended up having a machine shop build a duplicate of the correct one. I re-threaded the holes and re-installed them with grade 8 bolts and loctite. They slipped right in and I have no idea what could be holding them so firmly in place on your machine. But, it sounds like my experience is the exception and not the norm...
G
Tue, Dec 8, 2015 11:06 PM
ronm
Reply to Gregness:
G
Fire up Ol' Blue Rosie, get it cherry red, let it cool off...repeat as necessary, with applications of the loose juice in between.
Tue, Dec 8, 2015 11:19 PM
mrsmackpaul
Reply to ronm:
weld a big bolt to the middle and make a puller out if it slide a piece of RHS over the lot pin and bolt and some thick steel with a hole int the middle for the bolt and pull it out that way grind the bolt off repeat on the other side
It all sounds so simple hey LOL
Paul
Wed, Dec 9, 2015 2:43 AM
bcwayne
Reply to mrsmackpaul:
Paul
Thanks for the ideas....I had thought of welding a large nut to it and then a piece of all thread rod and a 25 pound barbell weight to create a monster slide hammer... maybe that and heat & loose juice will get it done.
Wed, Dec 9, 2015 9:06 AM
old-iron-habit
Reply to bcwayne:
Even the welding and cooling will help. Apply some wax against the joint when it is hot as he**. Whatever sucks in as it cools will help.
Wed, Dec 9, 2015 9:20 AM
