Removal of D4 thermostat
garyr
Send a private message to garyr
Does anyone have a removal method for extracting a thermostat from a D4 (7U1264) before I break out the hammer and chisel???
Wed, Jun 7, 2017 10:29 AM
Take two 3/8 capscrews and grind the heads to make the legs of a puller. You want them to grab under the retainer on one edge and jam against the thermostat on the other side when stood up straight. Then drop a spool of pipe bigger than the retainer over the two bolts and finally drill a piece of flatiron for them to poke up through and put nuts on. Tighten evenly and it pops the retainer out. Best results are with a short spool of pipe, short bolts and a fairly thick piece of steel on top, so there is less tendency for them to move toward the center and slip off.
Wed, Jun 7, 2017 11:41 AM
Thank you received: 77
Thanks cc, I needed to do this with my thermostat too - this will do the trick
Wed, Jun 7, 2017 9:51 PM
Andrew
I Think we need a photo of your themostat retainer puller.
Thu, Jun 8, 2017 4:53 AM
garyr
Reply to Andrew:
Thanks for the ideas. I was thinking to drill & tap a couple of holes in the retainer and use a bridge puller setup like that. There is a slot on each side of it
but they are pretty skinny to get a hook under. I guess Cat still sells them but if I can I would like to preserve the parts if possible.
Gary
Thu, Jun 8, 2017 5:18 AM
Mike Meyer
Thank you received: 6
Reply to garyr:
Gary
Cat make a proper puller for that ring and luckily I was given one by Eddie Bedwell a few years back, but before I got that neat tool I used my home made slide puller tugging on one notch at a time slowly pulling the ring out, remember when you re-install the ring to put the notches at the back for next time.
Thu, Jun 8, 2017 6:19 AM
