Recommendations on where to get Hyster winch parts
Showing 1 to 9 of 9 results
Barely Smokin
Send a private message to Barely Smokin
Hey all,
Replacing the control cables on the D4F Hyster winch on my D4D. It's the three-cable, three-lever set-up. Two cables were frozen. PO had welded the control housing to the dozer so that I couldn't reach the nuts on the levers....had to torch one cable off and grind another. 😠 Makes me wonder.
So, I picked up a recommendation for Thomson in Oregon. Any other places you guys recommend? I'm in VA, so somewhere on the East Coast would be nice, but not a gotta have.
BTW, got all the manuals for the winch from links on this site....so I guess I can ID part numbers if I had to.
Thanks!
D4D 83J2646
JD 790
JD 440
Tue, Jan 19, 2010 5:40 AM
Thank you received: 39
Tue, Jan 19, 2010 5:56 AM
Barely Smokin
Thanks, OM. Did you go through a distributor? How did you order? With P/Ns?
I have the old cables all bundled up. I was thinking I would send them off to a sales guy somewhere so there was zero chance (yeah, right) that I'd end up with the wrong thing. Whattya think?
D4D 83J2646
JD 790
JD 440
Tue, Jan 19, 2010 6:00 AM
Reply to Barely Smokin:
It was awhile ago, don't remember if it was a distributor or the manufacturer. Was out if Washington State.
Had to tell them what I wanted based on the old cables.
Was the #173-HTT-2-(length in inches) series for a D4D winch (same controls).
The only thing different about the Hyster "F" series is prior models are cast steel, the "F" is fabricated steel.
Tue, Jan 19, 2010 6:53 AM
Barely Smokin
OM, thanks for the info.
These guys say they can get them. They're local. Took the old ones in there and I forwarded the P/N you gave me on to them. We'll see how they turn out. They're saying over $100 each.
http://www.forestryconstruction.com/index2.html
D4D 83J2646
JD 790
JD 440
Mon, Jan 25, 2010 8:22 AM
Never heard of that source and I can't tell from their website where they are.
Hope your getting the right stuff as I seem to recall the price for new cables and a reworked lever control unit was about $1,000. And that was a few years ago.
Mon, Jan 25, 2010 8:34 AM
Barely Smokin
They're in central VA, just south of Lynchburg. I'm a little skeptical myself, but that's why I pulled the cables and drove there and handed them to the guy myself. If their eyes work, then they can at least give me cables that look just the ones I gave them, you'd think. And the counter guy said he was real proud of the quality of the ones he had. We'll see....
D4D 83J2646
JD 790
JD 440
Mon, Jan 25, 2010 8:39 AM
chriscokid
Barely Smokin
Check out the chapter 12 website, i have listed several places to get parts some of them have winch parts(general gear).
You can go to ACMOC homepage and click on chapters then select our region and they have a link to the website.
Mon, Jan 25, 2010 9:33 AM
Barely Smokin
Reply to chriscokid:
Barely Smokin
Quote quoted $161 per cable. Lead time one week. I'll post some pics when I get the cables...
D4D 83J2646
JD 790
JD 440
Fri, Jan 29, 2010 8:41 AM
That sounds about right......even if it does hurt😊 😊
Fri, Jan 29, 2010 12:37 PM
