Rebuilding a snatch block
Showing 1 to 7 of 7 results
Jdz
Send a private message to Jdz
I am putting a snatch block back together after cleaning it up and replacing some minor parts. I am using the same bearings, races, etc. After trying to put it back together 10-15 times, I’m about to give up. I can not make the holes line up for the hook/shackle on the top of the block. I’ve had it as close as an 1/8 of an inch and as far out as 1/2 inch. There doesn’t seem to be anything that makes it get closer or farther out. Anyone have any ideas?
[attachment=54450]F543B24A-37A1-4ED1-A2A5-7A49F15598C4.jpg[/attachment]
[attachment=54451]5E2811CF-A9B7-47BB-80DD-2FDEB75D402A.jpg[/attachment]
Tue, Jun 25, 2019 3:56 AM
Thank you received: 78
Turn the side plates around?
Tue, Jun 25, 2019 5:54 AM
Thank you received: 95
I believe Neil is correct as the sheave outer edges are not sitting fully into the radius of the cheek plate-- as is shown in the photo.
Simply pull the sheave pin and rotate the cheek plates around--you can likely do this without removing the lower pin in the cheek plates--swing the plates downwards--the angle out wards of the cheek plate upper pin arms will then be closer together and the sheave will be sitting against what appears to be a flat side face on the current outer face of the cheek plates.
Sometimes we do not see the forest for the trees and the answer can be simple --been there many times until I stood back and thought about things after a breather.
Tue, Jun 25, 2019 8:38 AM
Jdz
Reply to edb:
It’s not quite that simple. I tried changing the position of the nuts on the sheave pin but that didn’t help either. I’m scratching my head on this one. Sometimes I get it within an 1/8” other times it’s of by 1/2” and there doesn’t seem to be any rhyme or reason to it.
[attachment=54456]894327FD-E2BB-4086-A3E7-871359C466F8.jpg[/attachment]
[attachment=54457]BEF066E0-5D0D-46FF-BFC5-F2F894C982A7.jpg[/attachment]
Tue, Jun 25, 2019 11:57 AM
Reply to Jdz:
Any chance you flipped the pulley from its original position inside the housing?
Tue, Jun 25, 2019 6:28 PM
Reply to drujinin:
Also try turning the bolt and nut one flat at a time to see if there is some relief given. If it's old school manufacture, the bolt and nut heads may not be even
Tue, Jun 25, 2019 6:54 PM
jumbo
Send a private message to jumbo
"Unwind" the sides one turn. A Skookum, RopeMaster and other similar blocks like that do not fit tight. There is always some play in them.
A 16" Skookum weighs about 150 pounds and when we got tired of moving them in one piece through the brush we would break them down into sides and sheave. Putting them back together, you just spun the sides back until the yoke fit.
Nice job of restoration.
I'm not afraid of hard work; I can lay down beside it anytime and take a nap.
Tue, Jun 25, 2019 10:16 PM
Jdz
Reply to jumbo:
No, there was a gouge in on side where the cable slipped in between the sheave and the side. It left a pretty distinctive mark.
I’ve done that, when I do, it seems like there is too much slop in the block. The threads are course, probably 1 1/4”??? So if you leave it 1/6 of a turn loose, it just wobbles and every time you unlatch the snatch, it wants to unwind even more. It fit pretty tight before I took it apart.
[quote="jumbo"]"Unwind" the sides one turn. A Skookum, RopeMaster and other similar blocks like that do not fit tight. There is always some play in them.
Nice job of restoration.[/quote]
This is a 12” one. It’s still not fun to lug around. I think I will leave it loose and see how it goes. It sure seems like a lot of slop though. My others don’t have anywhere near this much slop. Maybe I can put a shim in there to take it up.
Tue, Jun 25, 2019 10:42 PM
