Rebuild kit for pony motor carb
Showing 1 to 10 of 12 results
Cat99
Send a private message to Cat99
Hello
Does anyone know of a good source for carb rebuild kits. The pony motor is on a d47u. Thank you
Thu, Feb 10, 2011 11:31 AM
ol Grump
John Deere used the same carb on pony motors on their 720 and 730 series tractors.
Thu, Feb 10, 2011 9:23 PM
Arthropod
Send a private message to Arthropod
Reply to ol Grump:
This place has a nice website and were very responsive to my questions. This link takes you to the appropriate kit for a D4. Well, the kit works on D2 and D4 ponies.
http://www.mcdonaldcarb.com/product_p/k2067.htm
Also, here are some details regarding carb and numbers, etc. from the carb shop website.
http://www.thecarburetorshop.com/TrackitsC.htm#TracCate
1949 D2 (pony engine) Zenith TU4C 10368 5F-3527
1949 D2, D4 (pony engine) Zenith TU4C 10365 5F-3530
1949 D4 (pony engine) Zenith TU4C 10367 5F-3528
Fri, Feb 11, 2011 4:56 AM
Cat99
Reply to Arthropod:
Thank you for pointing me in the right direction.
Fri, Feb 11, 2011 12:14 PM
64crew4x4
Send a private message to 64crew4x4
Reply to Cat99:
pulling an old post back up...😉
I am a mechanic.
I just bought a 1941 D4 Cat. All there....pony motor fires, but Carb is Dirty. So I want to rebuild it , then move forward with Diesel motor firing....
Are there any tricks to rebuilding this Thing....
I am looking for video now too....Its Small enough once apart I am going to Sonic wash it....
Old Iron is Cool, but I know things can be wacky sometimes.....
Thanks, John in Oregon.
Sat, Feb 27, 2016 1:07 AM
Thank you received: 57
Reply to 64crew4x4:
I am a mechanic.
Yes there are a couple of tricks:
- drill out the soft lead plugs, particularly those on the fuel bowl to gain access to the cross-passages that typically clog on this carb. Use a drill bit in your hand (important!) once the plug is out to drill through the gunk. Once you have them clean (feel free to check with us with photos if you're not sure), use BB pellets to plug the holes back up. Some epoxy them in - I didn't and mine don't leak - clean and round is what you want. Push the bb head in and the tail will also compress nicely to form a seal
- carefully separate the bowl from the throttle body and check that the bullseye gasket is intact. Your kit will have new one but if the old one is chewed out, it can indicate that it is worth skimming the two faces flat with a stone (by hand)
- if the main jet adjusting screw is oriented horizontally, then remove the cover over it and verify that the 90 degree crank that it bears on is actually 90 degrees - it's easy to over tighten and thus bend it
- check that the idle port brass plug is oriented with the notch at the very bottom. Disregard the orientation of the bar on the back of the plug - what's important is that the notch is lowermost - this will give a good idle
- if you need to remove the main jet, make up a good screwdriver that fits very well. They're in there good and it's easy to munch up the top of the jet body
- post pictures!
Sat, Feb 27, 2016 1:58 AM
blwatson
Send a private message to blwatson
Reply to 64crew4x4:
I am a mechanic.
Had good luck with McDonaldcarb.There was a good post on here about "Pony carb rebuild in progress" that had good pictures that included drilling out plugged passages, removing and replacing plugs for proper cleaning. I found it to be very helpful when I rebuilt the carb for my D47U. I found the post but all the pictures were gone. Perhaps someone else knows the post I am talking about and can come up the photos
Sat, Feb 27, 2016 2:02 AM
Important to remember that you adjust these carbs a little differently from most. All the idle mix screws are actually changing the amount of AIR that mixes with a set amount of fuel. So back them out to lean the mix.
I think the high speed mix screw will be normal (turn it out to richen mix). It screws in horizontally (has the little bell crank that was mentioned earlier) or screws in vertical depending on the year it was made.
When you reinstall the carb note that the "finger" on the throttle rod must be installed on the "far" side of the knob on the end of the throttle linkage pin to pull the throttle closed against the pull of the governor linkage. Pushing the throttle knob in should let the governor spring pull the throttle open.
The typical old carb that will run the pony only with a lot of choke and has no power turning the diesel is either experiencing mild fuel starvation from trash in the supply or float valve.......or most likely it has a plugged passage across the bottom of the bowl from the high speed jet to the high speed metering well. There is a hex head plug on the bottom corner of the bowl next to the throttle body that opens into the end of that passage but does not allow proper cleaning of the horizontal passage unless the soft plug is drilled. I used a bead of soft rosin core solder to plug that passage when I did mine. A .177 caliber lead pellet should also work well. Or the sealer coated BB's as already mentioned.
If it won't idle, then the idle port in the cast iron throttle body may be clogged as mentioned already. The brass jet is removable for cleaning only by driving it inward into the venturi (throttle body off the engine obviously!) When it is replaced, (tap in from outside) the grooves must be oriented properly so the fuel is admitted to the venturi at the proper point in relation to the edge of the throttle plate while it is nearly closed and resting against the idle speed screw.
Sat, Feb 27, 2016 9:24 AM
JAKEcatHT4
Send a private message to JAKEcatHT4
Im so glad to see that there is more in depth detail about rebuilding the pony carb since the last time ive been on this site. Ive had mine off the d4 ht4 for a going thru a few times over the past years and I think the last was a failure. Just glad to see more info and pics available these days. Hope my old cat part numbers are still in stock or I will be trying the john deere kit.
Sun, Mar 27, 2016 11:08 AM
cheshire cat
Send a private message to cheshire cat
Reply to JAKEcatHT4:
Great Information guys, just to add, many times when I've had pony running or running and losing power issues
I've found the fuel lines partly plugged with hard rust and dirt , so you blow them thru and they seem clear but there is still trash in them , I've found its quicker and more bullet proof to just make up some new ones out of copper line using the old fittings .....
Sun, Mar 27, 2016 2:00 PM
bexrex
Send a private message to bexrex
- post pictures!
[quote="Neil"]Yes there are a couple of tricks:
[/quote]
Well another gotcha I'd thought I'd share, since you are more than likely going to remove the fuel bowl assembly from the main carb body to get at the bolt to get the main body off the motor. The idle nozzle screw with a long thin small brass tube goes all the way through the body and into the fuel bowl. So when you separate the fuel bowl from the carb pull straight off, don't try to lever it off. see the end result in picture below
another gem - they don't make the part anymore. Luckily I found someone who had one, but no matter all the prep and searching and forum reading never preps you for the real experience of actually doing it.
[attachment=53506]20190415_120243Editied Arrow.jpg[/attachment]
[attachment=53507]20190414_173729.jpg[/attachment]
[attachment=53504]20190415_114513.jpg[/attachment]
[attachment=53505]20190414_171833.jpg[/attachment]
I hope this posting saves someone, since this post helped me get the courage to take it off as a "junior"
Wed, Apr 17, 2019 12:01 AM
