Rear engine oil seal on Gas 50
Showing 1 to 6 of 6 results
Jbayer
Send a private message to Jbayer
When we tightened the rear main bearing I repacked the groove in the cap with graphite. I used permitex on the back of the cap. I couldn't get a gasket to go back in it. It appeared that any oil that getts past the bearing goes down a passage back to the oil sump. Is there something behind the flywheel from the back side. The parts book is not clear about the seal.
John
Tue, Feb 3, 2009 9:34 PM
SJ
Send a private message to SJ
I don,t have any experience with a 50 engine but take the diesel engines say before the middle 1950s Cat had threads on the rear main crank journal and the bearing was engineered so the oil tended to be screwed back into the bearing and drained back down into the pan.There was no other sealing done on the rear bearing and area other than that. Later engines had a different setup,some with a lip seal and some with a metal ring like a piston ring and parts to be part of it,s function.
Tue, Feb 3, 2009 9:45 PM
WyoCat
Reply to SJ:
SJ is exactly correct. This type of seal was called a non-positive seal. Bearing clearance was fairly critical in them working as designed. These types of seals did not like any amount of crank case pressure.
Chad Enyeart
Tue, Feb 3, 2009 10:09 PM
side-seat
Thank you received: 8
Reply to WyoCat:
The thread is called a ''BUTTRESS'' thread. Make sure the drain hole is clear.
Tue, Feb 3, 2009 10:58 PM
d75
Send a private message to d75
Reply to side-seat:
Behind the flywheel is a cover plate held on by 6or10 3/8" bolts can't remember it has a felt seal that helps direct the oil back into the crank case. this is the hole that you remove the crankshaft through if so needed (alot of work😊 ) as long as the drain back hole is good and clear you should be all right.
Wed, Feb 4, 2009 9:58 AM
Jbayer
Reply to d75:
I made sure the return passage was clear. I must have some getting past somewhere. The cap has a groove on the OD to pack with something. I used some graphite but may need some cork. This is between the insert and the block casting. Thanks for the info. I assume it is engine oil comeing out of the bell housing.
John
Thu, Feb 5, 2009 6:21 AM
dick
Send a private message to dick
Reply to Jbayer:
John
I have always used the cotton wicking Cat supplied for sealing the holes on either side of the cap. I use a pin punch about 2/3 the diameter of the holes so you wont cut the wicking as you fold and pound it in with a little liquid Permatex as you go. I have never tried graphite packing but would think if hammered in good it would seal.
Thu, Feb 5, 2009 9:31 PM
