My experience W RD mags has been the rotor seems to go bad & bleed some spark to ground- although have had coils go bad but that usually results in no spark real quick-new rotors seemed real pricey so-- my cure has been to redo dist from slant 6 plymouth & convert to chrysler electronic ign..- same cure on pony on 2U's & 13000..
how far a gap will it jump? though i do not grab my wires to test, your crazy!
if it will jump 3/16 of an inch your good. i would try it to see if it will run.
a fairbanks is the only mag i do not have. i like the cat mags but i bet the
thing will run. some of my mags are weak, but still seem to run.
I am not sure but the rd7 should have a EISEMANN magneto
thanks guys
there is no measureable spark gap jump that is why i checked for spark with the old nerve endings
im going to dig around and see if i can find another mag
Does this mag have the impulse coupler? Kicks the rotor around quicker? Is that working?
I had a 17A with no spark and it ended up being the coil. Coil was pricey 10 years ago. Probably more now.
You should be able to get a good 3/16" spark or so by just spinning it by hand bench testing. You have solid copper plug wires that are good? Cap is clean inside? Bench test it using a solid wire from the plug hole to mag case, holding the wire with pliers for a spark gap.
If you can't get a good spark bench testing, then no use cranking the pony.
Hi guys. I don't post on here but this one needs attention.
Besides the usual suspects, the snap coupler (presuming it has one) needs to be good as said. The biggie with most all mags is the magnet itself. It's old. And weak. And can be recharged. There are people out there who will spiff it up for you and make life all sparkly again.
My two bits,
Gary M
It would help if you posted the serial number of the tractor.
The RD7's had a variety of Eisemann mags....including the ones with the mechanical timing advance (lever on side of mag).
Gary,
there's a sticky on the ACME site with a list of vendors - can you post the contact details of the magnet fixer-uppers on to that sticky for us?
Neil.
original equipment was the eiseman. i have seen one fairbanks on an RD6.
mine have eiseman, wico and cat. through the years people put whatever
worked on them as the original failed.
if you cannot jump a visible spark, it will not run. i have yet to see one that
needed the magnets juiced, but have had a bad coil or two. can you hear the
impulse click when you turn it.
