RD6 Track compatibility
Maddad64
Send a private message to Maddad64
G'day All,
Long time no speak. I've just renewed my membership and noticed it's been seven years and I'm still looking for a set of chains and plates for my 1939 2H series. In the interim I could probably get away with the plates. Can anybody tell me the range of Cat models, (if any), that would use compatible tracks I could use on my machine?
Best regards,
Qld Rod.
Mon, Feb 26, 2024 7:33 AM
Thank you received: 47
I believe the 4 & 5 r series D6, 8 & 9 u series D6 and D6 B all used the same pitch chain, just more links. Also some of the 955 track loaders used the same chain. And possible others such as a Cat 40 and R5.
Mon, Feb 26, 2024 11:47 PM
Maddad64
Reply to Ray54:
Thanks Ray, Do you know if the D4 6U or 7U is compatible?
Tue, Feb 27, 2024 2:33 AM
Thank you received: 50
Reply to Maddad64:
Same pitch but D4 track is narrower.
Tue, Feb 27, 2024 3:00 AM
Maddad64
Thanks Old Magnet, would that pitch be 171 and is it the chain that is narrower?
Tue, Feb 27, 2024 3:22 AM
Reply to Maddad64:
Pitch is 6.75" and yes the D4 chain is narrower.
Tue, Feb 27, 2024 4:27 AM
Maddad64
Sorry 171mm which is 6.75" Thanks for your help.
Tue, Feb 27, 2024 4:52 AM
Mike Meyer
Thank you received: 6
Reply to Maddad64:
D4 bottom rollers fit the RD6 track frames, if your front idlers are a bit worn, D4 tracks will fit, I have a RD6 running D4 chain happily.
Wed, Feb 28, 2024 2:05 AM
Reply to Mike Meyer:
I show about a 1" difference inside chain width and about  5/8" difference in sprocket widths. Seems it would be a very worn D4 rail to run on the RD6.
Wed, Feb 28, 2024 4:32 AM
