RD6 Master Pins
RD6 Master Pins
Showing 1 to 10 of 10 results
D8PETE
Send a private message to D8PETE
Hello All - What do you guys use to reconnect your tracks if your master pins are not reusable? I doubt CAT still sells masters for a RD6. Make a custom new pair?
Sun, Mar 31, 2019 10:15 PM
STEPHEN
That's what I would probably do, but I don't know what tools you have
Sun, Mar 31, 2019 10:26 PM
Reply to STEPHEN:
try the part no with Cat--they still have new pins for my D2---also try Florin---you never know!!
Sun, Mar 31, 2019 10:28 PM
Mike Meyer
Thank you received: 6
Reply to dpendzic:
My RD6 parts book says 2B5979 is the right pin but I can't see any in stock at my Cat Dealer or on Machinery Trader, it comes up a bad number, I'm sure there is a newer part number.
Mike
Mon, Apr 1, 2019 3:17 AM
Thank you received: 62
Reply to Mike Meyer:
Mike
I believe the RD6 track is the same as all other D6 up to and including the D6B. So hopefully master pins would be available from Cat and aftermarket.
Mon, Apr 1, 2019 6:12 AM
Mike Meyer
Reply to Ray54:
Good thinking there Ray, if that is the case then D6 5R master pin is 2F2567 which becomes 8M7456, price here in Oz from the Dealer is about $US30, plus 2 collars 4B5954 at around $US15 each.
Mike
Mon, Apr 1, 2019 6:22 AM
D8PETE
Mike
Hi guys - called Milton Cat this morning but the 2B5979 part number is discontinued. They looked in aftermarket and used parts but nothing came up. They tried searching with the track link number but still nothing came up. I’ll call Florin and see what they say.
Mon, Apr 1, 2019 9:15 PM
josh
Thank you received: 14
Reply to D8PETE:
I see a cross of 2B5979 to 2F7415.
Tue, Apr 2, 2019 9:36 AM
Mike Meyer
Reply to josh:
Thanks Josh, sadly my local Cat Dealer parts search shows that is a bad number too, I'm sure I bought a couple of RD6 master pins a few years back from the Dealer.
Fri, Apr 5, 2019 6:30 AM
Dozerman51
I just checked the part number with Florin Tractor, they show it as an aftermarket part and have 6 in stock as of 04-01-19.
Fri, Apr 5, 2019 8:15 AM
Mike Meyer
Reply to Dozerman51:
Thanks for that info
Sat, Apr 6, 2019 3:51 AM
