RD6 final drive oil fill level?
scooter3
Send a private message to scooter3
Good afternoon,
I am wondering how high to fill the final drives on 36 RD6? I have filled them to the bottom of the fill neck in the past.
I am also wondering if the transmission and bevel gear set share oil compartment or if they are separate? I only see one hex plug on top of the transmission and two level check plugs on the side (same location one above the other). I had the top of that off years ago, but do not recall.
Please let me know.
Thank you,
Scooter
Tue, Mar 10, 2020 2:01 AM
gemdozer
You should have a drain plug for the transmission and a second on for the bevelgear housing and 1 each side for final drive
Tue, Mar 10, 2020 4:15 AM
Reply to gemdozer:
Fill the final drives till the oil level is in the threads. Transmission/ bevel gear housing same oil, final drives are separate.
Tue, Mar 10, 2020 5:14 AM
scooter3
Thank you for the replies. Sounds like I need to add a little more oil.
Thank you,
Scooter
Tue, Mar 10, 2020 7:08 PM
