rd4 weight and transporting
Showing 1 to 10 of 13 results
lil cat mec
Send a private message to lil cat mec
I may be picking up an RD4 from California the end of may/beginning of June. What is the wet weight of an RD4? no blade, just a farm cat.. Also what are the laws in regards to transportation? I have a 26' tandem single tire gooseneck trailer with 8k (16k total) axles under it and I would be using my 93 Dodge Cummins. are there any special permits I would need to get?
1935 CAT 22 2F4455W
1990 CAT D6H 4GG04120
2012 CAT 272C RED02823
1971? CAT 951B 86J01212
Thu, Jan 29, 2015 7:17 AM
Skinner
Thank you received: 38
RD4 weight is 10030 lbs.
Thu, Jan 29, 2015 7:53 AM
gary ca
Reply to Skinner:
Technically, in California, if you tow a 10,000 GVW trailer, even unloaded, you need a Class A license (commercial truck license). This is not a law that is often enforced. But if and when you have to cross a scale, they could check for it.
if your truck is a 3/4 ton, you will not need a CA number. These scales are drive thru so as long as the weight is ok and you have everything secured properly, you should get the green light in your lane. Drive near the speed limit and keep the red flags to a minimum. This is California and you pretty much can't do anything without breaking some law.
Keep us posted on your trip. G
Thu, Jan 29, 2015 11:04 AM
lil cat mec
Reply to gary ca:
okay, here in Washington you can run up to 32k If I recall correctly without a CDL, I may call the California Department of transportation and see what they say, I would prefer to not get a ticket. I do believe the old grouch I will be purchasing it from will not let me leave unless it is all tied down to perfection
1935 CAT 22 2F4455W
Thu, Jan 29, 2015 1:59 PM
Thank you received: 62
Reply to lil cat mec:
You can check Calif laws on line.I just did some looking a month back. Something about farmers and employes good to 26,000 thousandth without anything but a class C,as long as the load belongs to the farm . Nothing is simple everything has to have grey areas so the lawyers can contest it. A commercial CHP officer that was at a farm meeting to explain said you are exempt hauling horses to herd cattle but not if going to a horse show,as that was for recreation.So check it out and decide how much risk you are willing to take.
Thu, Jan 29, 2015 10:02 PM
7upuller
Reply to Ray54:
Hey LCM,
Good to see you posting. "Not for Hire"... When you read laws, sometimes it states that when Not for Hire, it doesn't apply.when you do it for yourself and don't charge anybody, they look the other way. I know a guy with a 18 wheeler that blows every scale when hauling to a show. Farm laws give you a lot of room also. It is true in Ca over 10,000 in tow requires a class A license, but do some searches on the interenet. Heck you kids can do that interenet thingy faster than us older guys...roflmao
Thu, Jan 29, 2015 10:53 PM
old-iron-habit
Reply to 7upuller:
Hey LCM,
Traveling in more that one state puts you in Interstate rules instead of Intrastate. You can get by with a lot on farm rules but still get busted if a inspector has a crab on. Here our farm laws allow only 50 miles into the neighboring state under certain conditions. Take the backroads. You never know, you might see another must have. Last time I was in CA I seen a sign before the scale that said all motorhomes over a certain weight must enter. Whats that about.
Thu, Jan 29, 2015 11:56 PM
lil cat mec
Reply to old-iron-habit:
yeah, I wish it was 2016 already, I will be getting a class A through my work because I want to become a field technician. Ill have to look into it. I've called our state patrol and asked them before and they said you can get trip permits for overweight loads, hopefully ill get lucky and get away with that as well as a set of not for higher stickers.
1935 CAT 22 2F4455W
Fri, Jan 30, 2015 12:50 AM
Dieselholic92
Thank you received: 15
Here in Minnesota, you must have a CDL if the weight of the pickup, trailer, and the capacity of the trailer will put you over 26,000. It doesn't matter if you are hauling something far less than the capacity of the trailer, it's that you have the ability to haul that capacity. However, this only applies if you are hauling something to make money off of, or if you are hauling something that helps you make money. If you are in a privately owned pickup, hauling something that is privately owned and not for profit, then you are fine without a CDL. I have a buddy who is a farmer and races dirt track. He pulls an MCA Stock Car on a 14,000b capacity tilt bed car trailer and pulls it with a 1 ton long box 4 door Duramax. He has to have a CDL and DOT his pickup and trailer because all together that puts him over 26,000lbs and he can potentially make money at the races. How dumb is that?
David Gruhot
D & G Excavating, Inc.
Fri, Jan 30, 2015 2:40 AM
7upuller
Reply to Dieselholic92:
Hey Little Cat Mech,
You can go to Ca.Gov and search about trailering. If less than 26,000 GVW and not for hire, they will allow over 10,000 but less than 15,000 behind a 10,000 truck, so less than 26,000 with a class C license. Sounds like it will work. In Ca, no pick ups required to stop at scales. So, stay under 26,000. There is a private scale close by, we can check weights. glen
Fri, Jan 30, 2015 6:07 AM
lil cat mec
Reply to 7upuller:
I've contacted the state patrol about the issue and I've had mixed answers about what I need. One said I need a Class C CDL and the other did not. I do not have my CDL yet, It sounds like I will be going through the classes next spring. I will look into it more and search through the laws on line but I'm not sure if I want to risk it. only research will tell.
1935 CAT 22 2F4455W
Sun, Feb 15, 2015 9:37 AM
