RD4 Diesel lift pump leaking on input shaft
Showing 1 to 10 of 12 results
R4pat
Send a private message to R4pat
I was wondering what the lift pump on an RD4 was supposed to have for a seal. Looks like graphite packing, last I checked Cat doesn't carry a seal for it any more, here are some pictures of a scrapped out pump of mine,
Tue, Jan 22, 2008 8:06 AM
They went through a couple style pumps and seal arrangements. Looks like you will have to make do or move up to the next style pump from sr. #4G9568 to 7J635 that used a different double seal. I believe all of them were a graphite packing.
Tue, Jan 22, 2008 8:26 AM
R4pat
Old Magnet, do you mean get a different pump or do you mean the the seals for the 4G9568-7J635 will work in my pump
Tue, Jan 22, 2008 8:42 AM
Reply to R4pat:
That's a different pump.....still similar style....but uses different double seals and from what I can make out from the parts book the seal related parts are different dimensions and they are different part numbers.
May not get you out of the woods until parts availability was checked also.
Tue, Jan 22, 2008 8:45 AM
R4pat
Thanks Old Magnet, I think I will try making a new packings with some rope, and I will use a press to get that stuff packed tight, hopefully this will work, the old packing probably old, hard and drieded out, I appreciate your support
Tue, Jan 22, 2008 9:45 AM
R4pat
Thanks Old Magnet, I think I will try making a new packings with some rope, and I will use a press to get that stuff packed tight, hopefully this will work, the old packing probably old, hard and drieded out, I appreciate your support😊
Tue, Jan 22, 2008 9:46 AM
KidNV
Send a private message to KidNV
Reply to R4pat:
Pat, those leaded seals should still be available, I bought 2 from cat, last yr or the one before. Like $4 a piece.
Tue, Jan 22, 2008 11:44 AM
R4pat
Reply to KidNV:
KidNV, would you happen to have a part #, it isn't a later style pump like Old Magnet was talking about is it?
Tue, Jan 22, 2008 11:46 AM
KidNV
Reply to R4pat:
Pat, was just lookin it up.. 2A831 changed to 4B9051, then 5M6038. Got them from Foley Cat in KS in 05, for $2.47 ea. Their # is 620-792-5246. Steve or Mike
Tue, Jan 22, 2008 11:59 AM
Reply to KidNV:
KidNV,
Are you sure they are all the same seal?.....cause the spring, seat and retainer numbers all change to. Might be close enough to give you something to work with though....price is right.
Tue, Jan 22, 2008 12:55 PM
KidNV
KidNV,
OM, thats the ones I used on the pumps from 4G2195 and 4G7747... Just looked, mine has the same outer cover, it is from a later model and so is his, 4B9040 is the cover on the later style pumps. Needs to get 2 of them. They are graphited cloth rolls, packed in that shape, and are EASILY damaged if you bump near the center hole, yes, I did it once..
Tue, Jan 22, 2008 1:10 PM
