RD4 Caterpillar project
Showing 1 to 10 of 11 results
R4pat
Send a private message to R4pat
I've been currently working on this RD4 fixing leaks, working the starting pinion over. After putting a new thermostat, and cleaning the water jacket of the pony engine, I've finally been able to start without starting fluid๐Ÿ˜Š it did take 15 minutes to get the block hot enough, hopefully after a little work out it will get better. Right now I am wondering if someone can help me with some part #s for this oil filter which is not in my parts manual, alls I need is the #s for the filters, O Rings and the gasket or the copper ring that goes under the bolt head on top.
soon I will be going into the rear end, making popping noises when ๐Ÿ˜• , hopefully not bearings, and one of the stearing clutches slips
Thanks for any help or information
Mon, Mar 24, 2008 9:30 AM
Haole Cat
Send a private message to Haole Cat
Looks like a fun project. Judging by the photos, you a few nice projects.
Mon, Mar 24, 2008 3:47 PM
gwhdiesel75
Reply to Haole Cat:
Glad to see another RD4 saved and running.
Mon, Mar 24, 2008 7:19 PM
ol Grump
Reply to gwhdiesel75:
Can't help ya with the filter but for o rings and copper gasket you might try a good automotive parts house or hydraulic shop.
Mon, Mar 24, 2008 8:35 PM
Reply to ol Grump:
Lower can gaskets 5B5973 (2)
Upper can gasket 5B5937 (1)
Bolt gasket 5B8927 (1)
Upper element 5B8934
Lower element
(inner) 5B5983
(outer) 5B5984
Mon, Mar 24, 2008 10:44 PM
dewets
Send a private message to dewets
Lower element
(inner) 5B5983
(outer) 5B5984
Someone's bin busy widda cleaning process!
That shed's got quite a few yeller pieces about it!
Great. ๐Ÿ˜Š ๐Ÿ˜Š
Somerset West, Cape Town
South Africa
Tue, Mar 25, 2008 5:22 PM
Reply to dewets:
Great. ๐Ÿ˜Š ๐Ÿ˜Š
That has to be one of the first oil filters fitted, never saw one like that before.๐Ÿ˜„
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare time๐Ÿ˜„
Tue, Mar 25, 2008 8:03 PM
cr
Send a private message to cr
A lot of the early D4's and D2's had that filter. I have a few old old cats like that in the pile.
Wed, Mar 26, 2008 8:22 AM
R4pat
Reply to cr:
We have another RD4 real close in serial # to this one with the same filter
Wed, Mar 26, 2008 8:39 AM
R4pat
Reply to R4pat:
This week I decided to take a look at the rear end to find the noise I've been hearing, well, take look close look at the final drive gear in the picture, two teeth missing, and thats not all, one of the locks for the shifting forks was dangling, because the bolt and spring that holds it up broke, what kept it from getting messed up worse, I don't know, This broke gear is a straight tooth and a D4 has a curved to tooth, will both the gears interchange? probably going to have to replace the drive gear that runs this one also so the gears don't bind up. I'll be looking for gears if anyone knows of any
Sat, Mar 29, 2008 7:42 AM
Reply to R4pat:
Pat,
you need to find a "bevel gear" set. Final drives are on the sides between the steering clutches and the sprockets.
I don't have any parts book to help you , but I was not aware that any of the old CAT tractors had anything other than straight cut bevel gear sets.
You would probably be better off to replace the gears in a set, but you might get by, with careful adjustment, just finding a ring gear ( the large one, also called a crown gear by some folks). I blieve that replacing the pinion gear would involve some disassembly of the transmission beyond that necessary to set up the bevel gear set.
Maybe the gears will interchange with the later tractors.
Sat, Mar 29, 2008 9:05 AM
