Rattling while in neutral with clutch engaged, 1953 D4 7U
Showing 1 to 10 of 15 results
jstandle
Send a private message to jstandle
Hello,
I've noticed a little bit of an erratic rattle when my D4 7U is in neutral with the clutch engaged. Is this of any major concern? Everything still functions fine and there is no noise when the clutch is disengaged and also haven't noticed it when operating the tractor. I assume maybe the input bearing or some other main shaft bearing in the transmission has some wear?
Here's a video that you can hear the noise in;
https://photos.app.goo.gl/poUoLgIzZEl4Yxii1
Thanks,
Jordan
Wed, May 16, 2018 12:24 AM
bursitis
probably the gears knocking against each other at low idle. just idle up some till it smooths out.
Wed, May 16, 2018 3:13 AM
jstandle
Reply to bursitis:
It does smooth out with higher RPMS. I've got to pull my newly installed winch back off soon to fix leaks that appeared so thought if there is something I need to dig in to that now would be a good time.
Thanks,
Jordan
Wed, May 16, 2018 3:40 AM
bursitis
Reply to jstandle:
Thanks,
Jordan
[quote="jstandle"]It does smooth out with higher RPMS. I've got to pull my newly installed winch back off soon to fix leaks that appeared so thought if there is something I need to dig in to that now would be a good time.
Thanks,
Jordan[/quote]
i don't think it is a problem but just to be safe you had better get some more opinions.
Wed, May 16, 2018 4:33 AM
WA7OPY
Send a private message to WA7OPY
Reply to bursitis:
Thanks,
Jordan[/quote]
Maybe just low on 90 wt???....WA7OPY
Wed, May 16, 2018 9:48 AM
jstandle
Reply to WA7OPY:
No, I did check that and it's OK.
Thanks,
Jordan
Wed, May 16, 2018 9:59 AM
Thank you received: 77
Reply to jstandle:
Thanks,
Jordan
The pins on my D2's clutch are unevenly worn, so the thrust collar wobbles like a swash plate just a little. Yours might have the same deal. If so, new pins are readily available.
Wed, May 16, 2018 7:26 PM
bursitis
my 6U rumbles at low RPM and clears up perfect at around 500 RPM. most of my noise is coming from the winch gears i think. really big gears just idling on the end of a PTO that probably is transmitting some frequency from the engine. does this sound logical? anyone else with a winch experience this?
Wed, May 16, 2018 7:39 PM
jstandle
Reply to bursitis:
Mine was doing it before I put the winch on and I kind of thought adding it might help by adding some more rotating weight/drag to the main shaft but it didn't make any difference, maybe made it a little louder is all.
Jordan
Wed, May 16, 2018 10:01 PM
bursitis
Reply to jstandle:
Jordan
those are pretty big heavy shafts with straight cut gears. also when the engine is turning slow there is probably a bit of torque moments on the output shaft. i have had john deere and other tractors make similar noises at low idle when new.
Wed, May 16, 2018 11:17 PM
jstandle
Reply to bursitis:
Do you think a person should raise rev's to avoid having the noise? I would assume, though likely minor, it is causing added wear clanking around.
Jordan
Wed, May 16, 2018 11:31 PM
