Ran my D7-3T outta fuel
jonstark
Send a private message to jonstark
At the very first sputter I shut down suspecting low fuel. Sure 'nuff dip stick is dry. Put 12 gallons in the tank and tried to bleed the filter. Started with the pet cock on rear bottom then thumb screw top front finally opened bleed fitting on top front below thumb screw. All three spouted clear fuel when opened individually while the pony was cranking the engine over.
Moved on to the injectors by cracking them individually and all at once with throttle open. Was never able to get anything out of them.
One other thing... The throttle lever moves very freely forward to low throttle but all of a sudden is much harder to pull up to power. Haven't been able to discern whether it's the throttle lever or fuel control.
I don't have any books so can't refer to any instructions or illustrations. Please bear with my lack of info but where should I go next?
Thanks,
jon
1981 D3B, 1955 D7 3T, 1954 Ford Jubilee, 2001 Kubota L3010
Thu, Oct 25, 2012 2:31 AM
Thank you received: 46
Here is the Cat procedure for bleeding.
Note, there is no mention of "cracking the injectors", even though it is commonly done.
Fuel (throttle) is closed to prevent pumping excessive fuel in to the cylinders.
Thu, Oct 25, 2012 4:07 AM
jonstark
Thanks lots for that info.
Now I need to make a tool for breaking those bleeders loose.
jon
Thu, Oct 25, 2012 4:49 AM
I forget what size to start with exactly, but a 1/4" drive socket that's been "squished" on two sides is an easy way to do it.
Thu, Oct 25, 2012 7:18 AM
Old_n_slo
Send a private message to Old_n_slo
http://www.acmoc.org/bb/showthread.php?16306-Fuel-injector-bleeder-wrench-tool-caution-pics-attached-%29&highlight=
Thu, Oct 25, 2012 11:21 AM
jonstark
I was able easily to open the "vent" valves inboard of the injector pumps. After bleeding them as well as the filter tower I was able to start the engine. As a matter of fact I think the first piston to come up on compression fired off and it ran as smooth as ever.
Thanks OM!
jon
Fri, Oct 26, 2012 6:02 AM
