Radiator removal, best way?
Peter C
Send a private message to Peter C
Since I am removing the hydraulic pump off of my 22 for repairs, I thought I would like to change the radiator core at the same time. Does anybody have any thoughts on whether I could just remove the upper tank and side plates then replace the core or would it be better to remove the radiator as a unit and disassemble it? [attachment=36907]20160718_083650.jpg[/attachment]
Pete
Tue, Jul 19, 2016 12:41 AM
STEPHEN
If the bottom bolts holding the core are half rusted away, it would be easier off the machine. If the core is completely messed up you could take it apart like a copper thief, i.e. saw across the top & bottom of the core to remove the major chunk and main impediment to easy bolt access.
Tue, Jul 19, 2016 5:05 AM
Skinner
Reply to STEPHEN:
Remove it as a unit works best for me. Then lay the radiator on a table that way you can get to bolts easier JM
Tue, Jul 19, 2016 7:11 AM
janmeermans
Reply to Skinner:
As G Pete said, some of the lower tank bolts may be partly rusted away. I had that situation on my TWENTY tank and had to get a new pair of vice-grips and use heat to get them out. You need the radiator off and a table as "skinner" suggests to do that.
JanM
Tue, Jul 19, 2016 11:15 AM
Peter C
Reply to janmeermans:
JanM
Okay, thanks for the input. I will remove it as a unit. It has a leak somewhere down low that doesn't show up in the core as far as I can see. I don't want to ruin the core in case the leak is in the lower gasket or tank.
Pete
Wed, Jul 20, 2016 1:30 AM
| Hartley - South Australia
