Radiator color
Radiator color
Cysco
I finally got the radiator back from the shop. What color is the core painted or is it even painted ?
Thu, Jan 28, 2010 8:30 AM
Hi cysco,
all the cores at The Dealer were painted black from Cat or the outsource Radiator repairers, and always the thinnest of coatings to aid heat conductivity. Black has been determined to be the colour of best heat transfer in either direction, ie, taking in or giving out from the surroundings which in this case is the air stream.
Thu, Jan 28, 2010 3:34 PM
Cysco
Reply to edb:
Hi cysco,
[quote="edb"]Hi cysco,
Eddie B.[/quote]
Hi Eddie.......I have heard that paint will sometimes interfere with the heat transfer but I am assuming that depends on how much and color that is applied. I know the "high temp" paints are thinner and tend to adhere better with the temp variations.
Thanks for the info
Have a good day.........Bill
Thu, Jan 28, 2010 5:36 PM
Painter
Send a private message to Painter
Reply to Cysco:
Eddie B.[/quote]
Thanks for the info
Try eastwood.com, for radiator paint, it is black, non insulating paint made for radiators.
Hi, My name is Dennis, and I am a Rust-a-holic!
D4 7U17091 D6 8U10305 1926 Cat 30 1955 Ford T800, 74 Ford LT9000 1936 K Allis
Thu, Jan 28, 2010 8:05 PM
steeltracs
Thank you received: 5
Reply to Painter:
Don't use regular paint, radatior shops use a paint that is specially made for this use. The old oil based type is much better than the newer water based types, dries faster too!
Fri, Jan 29, 2010 10:16 AM
Cysco
Reply to Painter:
Thanks everyone...there was no paint ,except overspray, on the core when I bought the D2 so that is why my inquirery.
Painter.....I have used Eastwoods paint products on my car restos and have found them to be high quality.
Thanks again everyone...........Bill
Fri, Jan 29, 2010 6:53 PM
