Rack setting gauge pt no. 3H1690
Larry
Send a private message to Larry
Anyone out there have the instruction for the above tool. I need to check the rack setting on a 3U grader with a D315 engine. Unfortunately, it`s been about 50 years I since last used one and have forgotten how-old age you know. I know that you have to pull an injector out and place the gauge in the injection pump hole but don`t know what measurements to use. I have a rack chart but it`s for the old system. This may be a question for Old Magnet. Thanks in advance, Larry.
Sat, Mar 31, 2018 12:27 AM
Yes I do....
Rack setting for the 3U using the 3H1690 tool is 0.330".
Sat, Mar 31, 2018 2:22 AM
Larry
Yes I do....
Many thanks, Old Magnet, I knew that I could count on you. Have not been doing too many repairs lately. Old age taking it's toll. Got my sawmill running last year. The old D315 handles the 48" blade very well. Had to convert friction drive to full hydraulic. What a difference. I used Cat parts wherever I could- hoses, hydraulic fittings, hardware, etc. I hope in the next month that the weather dries up so I can get sawing. The old D315 sounds very good under load, music to my ears. It got a full overhaul and sat indoors for about 30 years before I got it mounted in a frame above the husk frame for the saw. Old girl fired right up ready to do battle with the logs. Sorry I can't post pictures, don't know about the posting. Have necessary cameras though. Cheers, and thanks again, Larry.
Sat, Mar 31, 2018 10:15 AM
Reply to Larry:
Pictures would be great if you can figure out the posting.
Sat, Mar 31, 2018 12:06 PM
